Results 14 to 26 of 37
    Jul 2011
    Daikin EWYD-BZ scroll inverter heat pump chiller
    I found scroll inverter heat pump chiller Daikin EWYD-BZ, but can not find SEER info. Can anybody help?
    Aug 2009
    Prattville, Alabama
    Why is a "research scientist" doing his research by polling strangers on an open internet forum? No offense intended, Citon. I just can't shake this feeling of being....played.
    Jul 2011
    I got involved in energy saving of local buildings, and found it very difficult to get comprehensive information about best industrial chillers through dillers. Can you recommend better source of knowledge?
    Jul 2009
    Quote Originally Posted by jayguy View Post
    the 'optimal' chiller is......no chiller.
    heat pump chillers are getting popular now. you really need to consult a local factory office for ideas about your specific application.
    I would agree on contacting your local rep/office.
    We just installed two 170 ton scroll heat pump chillers (York - YCWL) that are fed from a geothermal field. Each chiller has five scroll compressors each and are working great.
    Beware - heat pump machines are totally different animals.
    Aug 2009
    Prattville, Alabama
    Citon, This site is a good source of knowledge. It is also a source of opinions. Good luck. I would start with jayguy's (and mkn8632) suggestion. Your local rep can probably set you up with a visit to another customer with an application similar to yours. As to "best industrial chiller", you're liable to only find who does the best job of marketing their particular set of numbers (that is, from the OEM's). BTW, what is "dillers"?
    Dec 2008
    Dixiana, AL
    Quote Originally Posted by Nuclrchiller View Post
    ..BTW, what is "dillers"?
    Those are cold water pickle coolers. Not very popular in the U.S., but catching on quickly in developing European nations.
    (Sorry, I couldn't help myself.......)
    May 2011
    hey how much heat do u need in the winter and do u have any electrical load #s for the building?
    bc tecogen makes a few products that would work but u would need more then one piece of equipment
    Heavy Duty
    windy city
    Quote Originally Posted by Citon View Post
    disposable junk
    \m/
    original member of the racoon brotherhood
    put a drive in it...put a drive in it...put a drive in it...put a drive in it...put a drive in it...put a drive in it...
    that's all i hear any more. drives are not the answer to everything. drives have their place, however, drives cost more up front, cost more to replace than a standard starter and they DO consume more energy above 95% (typically) than a standard starter.
    again, drives have their place and i like most of them, however, more and more drives are being used today in place of proper engineering.
    a properly engineered AND THOUGHT OUT chiller/boiler plant without drives is much easier to control and is much more energy efficient than a piece of garbage where drives are thown on to everything to make up for poor engineering.
    Jul 2011
    Quote Originally Posted by heavyduty2010 View Post
    Heavy Duty
    I need about 400 ton of cooling in summer and about the same amount of heating in winter.
    Jul 2011
    variable speed versus constant one
    ... a properly engineered AND THOUGHT OUT chiller/boiler plant without drives is much easier to control and is much more energy efficient than a piece of garbage where drives are thown on to everything to make up for poor engineering.
    Let me give you an example: variable speed Turbocor water cooled chiller has IPLV of 8 - 9 kW/kW. Carrier variable speed screw chiller 23XRV EVERGREEN® and centrifugal 19XR EVERGREEN® come close to this.
    Do you know any "properly designed" constant speed machine of similar efficiency?
    Aug 2009
    Prattville, Alabama
    The quote from jayguy is correct. The numbers from Citon (8-9 kW/kW) are confusing. Is that a typo? Regardless, this is comparing apples to oranges,or, plant efficiency to one component's (chiller) efficiency.
    Jul 2011
    I wanted to compare chillers with chillers. IPLV of 8-9 (in kW of cold per kW of power) is rather realistic. Just look at the technical data of those chillers.
    If you like to talk about plants, look at this review article, which shows 30 - 50% economy comparing to constant speed plant
    "All-Variable Speed Centrifugal Chiller Plants: Can We Make Our Plants More Efficient?", by MT Hartman, The Automator, Automated Buildings March, 2002
    http://www.automatedbuildings.com/ne...rtmn/hrtmn.htm
