Results 1 to 8 of 8
Thread: A/C question
10-10-2005, 05:45 PM #1
- Oct 2005
- 2
if your suction side gauge pressure is low what could be the problems besides low frion
10-10-2005, 05:50 PM #2
- Oct 2005
- Tempe, Az
- 7
No fan, dirty air filter
10-10-2005, 06:18 PM #3
possibly a restriction in the metering device.
Life is like a jar of jalapenos. What you do today might burn your ass tomorrow.
10-10-2005, 06:45 PM #4
Low on gas, restricted exp. valve, restricted drier, low ambient temp. causing low head pressure...
"If anybody can draw on the power, where do we put the meter?" - JP Morgan before pulling Tesla funding
10-10-2005, 06:50 PM #5
- Jul 2001
- 3,112
gage out of adjustment
10-10-2005, 07:30 PM #6
- Apr 2005
- 18
weak compressor valves....
10-10-2005, 07:56 PM #7
- Oct 2005
- Georgia
- 5
What is your head pressure and outside temperature?
10-10-2005, 08:09 PM #8
blikmik
As simply as I can put it.
a) low refrigerant flow into evaporatot.
1) low refrigerant level
2) restriction causing low refrigerant flow
b) low air flow
1) filter stopped up
2) indoor coil stopped up
3) Blower motor not running ( or not running at
correct speed )
4) Can't pull enough return air ( ductwork )
5) can't push enough supply air ( ductwork )
6) Return air bypasssing coil
c) low indoor ambient temp:
may also be helped by low outdoor ambient at same
time.
