Results 1 to 13 of 14
Thread: best method
    Aug 2005
    what is the easy and best method to clean central airconditioner cooling coil.
    Oct 2005
    Des Moines, Iowa
    evap. or cond. coil???
    Aug 2005
    evaporator
    i allready mention cooling coil is evaporator .my friend nosplumheat
    Oct 2005
    Des Moines, Iowa
    sorry i tend to read a lil to fast and read over stuff and not even think bout it.
    anyway, get A coil cleaner in a can open pleunum to get to coil and spray it down thats the easyest but not the best because you cant get to the dirtiest part or the coil the underside!! depending on how it was installed you may be able to move it out enough to get to the inside and use cleaner, fin comb, and rag, but if not u dont haveto many choices.
    Oct 2005
    Des Moines, Iowa
    in my world there is no "cool" absence of heat!!
    Aug 2005
    thanx buddy
    thanx for ur concern nosplumheat.
    Remove refrigerant from coil.
    Remove coil from house.
    Remove dirt from coil (water & coil cleaner, properly diluted.) Wear protective clothing & PPE.
    Repeat as necessary.
    Reinstall coil. (Flow nitrogen while brazing.)
    Install filter drier, (be sure to remove the old one).
    Leak test, evacuate, and reinstall refrigerant.
    Clean up the mess.
    If you lack the skill, tools, and/or certification, refer to the yellow pages.
    Good luck.
    Oct 2005
    Des Moines, Iowa
    i hope you dont do that with every tune and clean b/c that would get realy expensive for the HO.
    forgot to ask was it service regularly??
    Not on a routine preseason.
    Only on those that have not been properly maintained.
    And yes, it is expensive.
    Palmdale, CA
    That's the only way to really get a clean coil. Yes it can be expensive but what are your alternatives? Charging for a cleaning that isn't really clean.
    Southern Alabama
    What about a unit that is regularly maintaned? Agreed, pulling out the coil and cleaning is the best way. But, that is not going to be done every cleaning. Cleaning the coil in-place is someting that I feel must be done also to remove what has bypassed the filter.
    I have a lot of units that I service and I have been cleaning the coil with a brush and some coil cleaner. The problem I run into is how to clean the inside apex of an a-coil.
    Anybody have suggestions on what is the most effective way to do this?
    Oct 2005
    Go in through the limit switch opening with a small shopvac hose and sweeps away...........
    (kids, don't try this at home)
    Oct 2005
    I wonder about this too. Theoretically, couldn't you get above the coil with some pressurized air and blow the crap off the bottom and scoop it out of the blower. Or, maybe, remove the blower first.
Comfortech365 Virtual Event
