Thread: long line set
    Oct 2005
    what do you have to do to a long line set over 60ft
    SE Michigan
    Best advice would be to consult the installation manual for the particuliar equipment that you are working with.
    “Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery.”
    BAM
    The whip ladies and gentlemen! A first round KO.
    Jan 2003
    step it up
    Go one size biger on the suction line. for example if it call for 3/4 then go with 7/8. You might have to add a ounce of oil and some freon, but you should be ok..
    read manual it talks about this.
    regards
    Kelvin
