    Oct 2005
    what happens when you front seat the discharge service valve on a compressor while it is running?
    burlington county n.j.
    bad stuff
    Dec 2003
    The head pressure will go through the roof and more than likely, the compressor will trip on the O/L. You can front seat the king valve to pump the refrigerant into the reciever, but with a discharge valve the refrigerant doesn't have anywhere to go and it could hurt you and/or the compreswsor so don't do it.
    Apr 2004
    Are you sure you mean discharge or did you mean liquid. There's a huge difference in what happens.
    Jul 2001
    Gold Coast of Connecticut
    Most compressors equiped with a discharge service valve have a H.P. controll. If it is a tin can is probabley has an internal pressure relief.
    Aire Serv of SW Connecticut- Gas heat, dual fuel and central a/c systems installed and serviced
