Results 1 to 10 of 10
Thread: Furnace problem
    we have a very old electric gas furnace that once it turns on the fan will not shut off. does anyone know what the problme might be. thanks for any help.
    Oct 2005
    Hicksville ny
    Could be the limit switch that controls the on/off fan function.
    any suggestions on what to do with the limit switch to fix it.
    Rapid City, SD
    It could be several things, and not only is it hard to diagnose over the net we're not allowed to do it anyway.
    Best bet is to call a pro and have them fix it. Most likely there's a reason that caused that problem, and a pro can fix that aswell eliminating the chance of the new part breaking soon too.
    Suppy NC
    you are talking high voltage and a lot of differant controls here the best thing to do is call a pro and have it repared properly and serviced at the same time
    SE Michigan
    Kick the side of it and see if it stops.
    "If anybody can draw on the power, where do we put the meter?" - JP Morgan before pulling Tesla funding
    When was the last time you had that unit cleaned and inspected?
    Now you have a problem with the unit. Fuel costs are skyrocketing.
    So why not call in a professional to repair the unit? While they are there they can clean and inspect your unit to insure a safe living environment for you and your loved ones. Not to mention, having an efficient running system could save you more than the cost of the service.
    What's your safety worth? I'm guessing more than the repair bill.
    (we can't help DIY, due to site rules )
    May 2005
    Seabeck, WA
    It could be as simple as your fan switch is in the "pull on" position.If there is a button on it, push it in.
    Live for yourself and ask no one to live for you.
    You either have a sticking fan switch or you did like a lot of homeowners do, turned the fan setting on your thermostat to "On" instead of "Auto" when you turned your heat on. If you didn't do this, call your HVAC Pros.
    Inturmoil, if the "summer switch" you are referring to was in the on position, the fan will run until power is disconnected to it or the fan motor burns out, whichever comes first, not just when the heat is turned on. Most homeowners don't even know this switch exists.
    Senior Tech Guest
    Call a pro...before furnace go BOOM!
