    Jan 2003
    Kentucky
    Question
    works on Rheem residental equipment have problems with the suction line accumulators leaking, and the indoor coil? ...or am i the lucky one here?,and if so i wonder why?....replaced a bunch this summer,and countless ones since i started working for present company....if you run up on a Rheem and its low,run your detek across the top of the accumulator and chances are it will go crazy....if not, pull coil cover and you should strike a cord here...just wondering if everybody agrees etc...
    Grottoes VA
    I have had a lot of evap leaks on the Rheem's but have never had an accumalator leaking.
    Knock on wood.
    I had a rash of them about five years ago, (coils) no Accumulaters.
    Rare to see any brand around here with accumulator leaking. Maybe the comp quits before that happens!
    Almost no coil leaks on Rheems either.
