Results 1 to 13 of 28
    Exclamation how to observe refrigerant in household refrigerator
    Hi everyone,
    I want to investigate refrigerant flow in a household refrigerator and learn its quality in evaporator and condensers. But it seems to me too difficult and I do not know any method for it. Is there someone could help me on this hardship? And is there any kind of paper or engineer, scientist, etc. you know about working on this kind of study? Is there any equipment that make able to measure of quality of the refrigerant?
    Central VA
    Jun 2005
    Tampa,Fl
    Think"Mass spectrometer"
    Quote Originally Posted by cascader View Post
    thank you cascader,
    but mass spectrometer works on samples of elements. All I need is to observe the refrigerant simultaneously while the refrigerator works. Thanks again.
    Jun 2005
    Winston-Salem NC
    Get exposed to radioactive material and develop super powers I guess.
    You could theoretically make glass tubes that could stand the pressures, but the heat transfer would not be very good.
    Quote Originally Posted by stonewallred View Post
    Glass tubes make me just able to see refrigerant inside the tube. It is not possible to calculate its quality inside it by using glass tubes. My aim is to calculate its quality while the cycle on. I have never thought about radioactive materials to inside it and I have not any idea about them. Could you inform about it to me? How can I observe these radioactive materials inside allumina or copper tubes and in which way can I determine amounts of liquid and vapor? Do you have any idea? And thank you very much for your interest also your help.
    Cochrane, AB
    Quote Originally Posted by newbieeng View Post
    Quality as in chemically or physical state? Find a pressure/temperature chart and make the necessary measurements.
    New jersey
    I would say with temp press chart and monitor superheat n subcool. Also take temps at every predetermined length.
    If you can't explain what you do, then you don't really understand it!
    N.E. Iowa
    newbieeng, define "quality" as you used it in your original post.
    I am getting the impression that what you are asking is "how do i know what state the refrigerant is in (such as gas or liquid) in each component of the unit I am working on?"
    Am I correct? If that is what you want to know, then you don't have to physically see the refrigerant to know it's state. As was said by mspanky, a temperature/pressure chart will tell you whether the refrigerant is in a gaseous or liquid state by using the correct refrigeration gauges.
    If you are concerned with the actual quality of the refrigerant, then you would have to take a sample and have it analyzed. Seeing the refrigerant won't tell you if it's contaminated, although sometimes you can tell by the odor if there has been a problem within the system.
    ______________________________________________
    Sign petition to limit Congressional and Senatorial terms. http://www.termlimits.org/
    "We may have all come on different ships, but we're in the same boat now."--Martin Luther King Jr.
    Quote Originally Posted by Fabrk8r View Post
    Thanks for your interest Fabrk8r. That I wanted to mean with "Quality" is that mass of liquid phase of refrigerant divided by the total mass of it (mixture). I am not interested in the refrigerant's state, I want its real properties, qualitatively. You are right about charts, with the data provided by tranducers we can obtain its phase, quality, in shortly its thermophysical properties but in reality, it does not fit the actual one. In the system there are a lot of losses. Flow characterization during the system on seems impossible using that kind of implementations (using transducers of temperature & pressure). My aim is to explain its characterisation simultaneously, without cut-off the system. Some methods for measurement of mass does not fit in that way. Thanks.
    N.E. Iowa
    with the data provided by tranducers we can obtain its phase, quality, in shortly its thermophysical properties but in reality, it does not fit the actual one. That right there is Greek to me (I don't understand)
    In the system there are a lot of losses. I can agree with this statement.
    More Greek. Thanks.
    I'm sorry, but I don't think I can be of any assistance in this matter.
    I might be able to hang with you here....
    Problem is, I don't think you are going to like my answers.
    Determining the mass of liquid refrigerant in the system at any one given time during operation is going to be tricky because it will change as operating conditions change.
    I supposed that, if you can measure the ID of the tubing, the length of the tubing, then calculate the density of the refrigerant contained in it, you could come close, but you still have a varying amount contained in the condenser and evaporator as well as variable temperatures.
    I don't know of any way to account for these variables, but then again, I'm not the engineer.
    Jun 2010
    Miami
    I'm with JP. Weight and density along with temperatures and pressures can provide answers. However in any real system things will be changing all the time. Something like a chiller would be closer to steady state. Thermodynamics, basically being four dimensional, is never easy.
    Maybe if we knew what the goals were it would help. Are you an engineer, inventor, student, or scientist?
Tags for this Thread
