Why is it that N2 is not expressed as just N? Also H2 is expressed the same way? Just H? Roy
atom - The smallest existing particle of a pure element that can exist and still maintain the properties (or chemical characteristics) of that element. It is made up of protons, neutrons, and electrons. Example: Nitrogen is an element. Nitrogen molecules (N2) are made up of two nitrogen atoms (N). Many elements exist in nature as molecules of one or more atom.
Inert Gases
You have atoms and you have molecules. An atom is the basic building block of matter, the smallest piece of a chemical element.
A molecule will consist of two or more atoms joined together to become relatively stable. Atoms that form molecules undergo a chemical reaction, they react with other substances including atoms of the same matter.
True inert gases have atoms whose electrons are organized to be stable. The true inert gases consist of individual atoms. Examples are Helium (He), and Neon (Ne). Radon and Xenon are truly inert gases as well, I just cannot remember the exact chemical abbreviation tho I would guess Ra & Xe. Another name for a truly inert gas is a noble gas.
True inert gases do not react with anything, including themselves, they are a 'cloud' of single atoms.
N2 is an example of atoms of the same substance that react together forming molecules that share electrons to become a fairly stable 'cloud' of molecules.
The N2 molecule is stable until a lot of heat is added but N2 is not truly inert. You add enough heat at a high enough temperature, such as what occurs inside an internal combustion engine and that N2 will react and form the compounds in smog.
A lot of other substances create molecules with themselves, such as H2 and O2, but these gases are a lot less stable than N2. A little spark and they make water, compared to heating N2 up by a 1800 hundred plus degrees.
http://www.ductstrap.com/
I stayed at a holiday inn express last night.
It would be ok, but you shortened up the first paragraph.The rest is fine.
What are you talking about?
Quite the button pusher, it's getting boring.
A 'guy who can't trouble shoot a resi gas valve' goes out of his way to get my attention in this thread.
gruvn has been oddly quite the past few days hmmmmmmmm. I see a pattern.
Dont go after Carnak rookie!!!!!!!!!!!
The gods will strike you down.
LOL...good one C!...
In honor of Murray Woodgate (aka Carnak) 1961 - 2010
Originally posted by remis
You sure about that ?
Remis, Beavis, or whatever you call yourself.....Please Go Away!....
Looks like about 4 of his threads went away already
- You may not post replies
- You may not edit your posts
Forum Rules
