Results 1 to 13 of 15
    Jul 2002
    Chariton, Iowa
    Is overwiring allowed by the NEC? For example using 10awg wire for a 20 amp circuit instead of 12awg, 8awg for 30 amps, etc.
    Apr 2003
    Why wouldn't it be?
    Cincinnati
    What you read in the NEC is minumum. So if I'm reading your post properly then yes you can use bigger gauge wire than the NEC states.
    Just make sure you run it the way your inspector wants it cause you don't want to do it twice.
    Dec 2003
    Location!, Location!
    "overwiring" like you mention is actually "allowing sufficient conductor area for minimal voltage drop" and is required, like the #10 on those 20 A circuits, when distance or load(large motor-starting) requires. I have installed Vac-Pak machines that required #6 for a 30 amp rla.
    Dec 2003
    under-wiring is allowed also, on motors. You couldn't Over-wire if the terminal cannot handle the size of the wire that you install. They make pressure connectors, or other means for downsizing the conductor to fit into a terminal. Haircuts are not allowed.
    there but for the grace of god, go all of us
    Jul 2002
    Chariton, Iowa
    Thank you all for your replies. I just didn't know if it was allowed for short runs but since it is I will plan accordingly. I only ask because I lived in a mobile home that only had 2 15 amp 14AWG circuits for receptacles, lighting, and the smoke detectors running the entire length of the house (1 on each side) and any time anything such as the refrigerator kicked on it dimmed the lights severely. So I am assuming it would also be OK to have an electrician wire an entire house with 20 amp branch circuits and #10 in rigid conduit to the boxes then 12AWG 6" pigtails to the actual receptacles (so the wire fits under the screws properly).
    Dec 2003
    if he is wiring a house in rigid, he must be a glutton for punishment.
    Rapid City, SD
    True, but it'd be a way cool house wouldn't it! When I remodel I plan on doing a couple things rigid so I can "finish later" lol. But a whole house... wow.... wouldn't want to see the bill for that one.
    Cincinnati
    I ran rigid underground for my pool. Have you ever threaded rigid?? Maybe it was just my pipe threader but it kinda chipped up the threads on the pipe. Still worked but the threads looked crappy.
    What's wrong with plactic conduit for underground? We use pvc conduit around here all the time and we have rocks.
    Jul 2000
    Dallas,Texas
    Did you use NPT threader dies?
    Rigid conduit requires NPSM. No taper.
    Cincinnati
    That's what it was.
    I didn't use pvc or emt cause you had to dig the trench twice as deep and I was the only one digging and it was 90+ out there.
    Florida
    That's what it was.
    Don't blame you there, but trenchers rent inexpensive. Is that a local code on trench depth depending on what type of conduit?
