    Jun 2011
    Confused Water in the vents
    Needing some advice on how or why Ive got water running out of the base of heat system located in the basement when I turn the ac on. AC unit is located seperatly outside tho both are connected through vent system. Can hear water running down heater vent pipe but pipe has mushroom cap. Been having record number of tornadoes, straight winds and rain.
    Sep 2010
    Western, MO
    You need someone to come out and check you condensate drain.
    Call a service company in your area.
    jim
    Common sense isn't very common anymore.
    Jul 2010
    georgia
    no idea. did they run the AC's condensate into the furnace's exhaust system for some reason? Doesnt sound very kosher if so.
    Rochester, NY, USA
    Quote Originally Posted by SwampedinMissouri View Post
    you have a plugged a/c drain. Call a pro to have the drain checked.
    Skilled Workers are hard to find
    Thats why idiots are promoted to management
    Jun 2011
    Thanks to all that responded. With 3 different pro's booked up for the rest of the week, I at least know where to research the problem and attempt to clear the clog myself if possible.
