Thread: calculating cfm
    Oct 2005
    Charlotte,N.C
    how can I calculate the cfm per ton of a system using your temp.drop and static pressure can't remember formula and how can you figure static pressure with digital monometer thanks for the help
    Jul 2005
    Orange County, NY
    Buy a static pres. tip for you manometer, drill hole, stick tube in and read pressure.
    Don't have a tip. ...use a small piece od 1/4 inch copper tube and just insert the tube about 1 inch into the duct.
    As for airflow what do you really want to know? Actual CFM at discharge or actual BTU's of your evap. coil?
    Core
    Jul 2005
    Orange County, NY
    Velocity = 4005 * (square root) of Velocity pressure
    CFM = area * Velocity
    Core
    Oct 2005
    Charlotte,N.C
    cfm discharge
    Central Kentucky
    Do you have the fan performance data for the piece of equipment you are working on?
    Have you set up a Google alert for Carbon Monoxide yet?
    Click here to find out how.
