Thread: venting
    Feb 2005
    hello
    i having a system installed in the attic 80% the question how close can the venting pipe be install to an open skylight?
    thanks
    South/West of Quebec in the other part of Canada
    this is an odd question? Manufactures' data sheets only deal with sidewall venting clearances, Our local code book deals with chimney height clearance..Have your contractor research it and give you an answer prior to installation..
    34.8n 102.4w
    If the furnace is running , why would you have your skylight open ?
    Still, I would move as far as possible from any opening...flue gases in your home are not that great
    Florida
    Regardless of code, I'd go as far away from that skylight as possible. JMO
    SE Michigan
    I would say at least 5 feet.
    “Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery.”
    Feb 2005
    i ask the installer and he said the same thing why would the sky light be open. but one never knows what could happen.
    code is five feet
    thanks
