Results 1 to 13 of 22
    Oct 2008
    Indianapolis
    Last Friday's Install
    York 16 SEER A/C with modulating gas furnace - communicating
    Indiana
    you line-set runs into the ground..is it in a PVC chase or how did you do it?
    Ontario Canada
    Nice clean install.
    The only thing that sticks out is the electrical on the Condenser. No other way to do it?
    Never give up; Never surrender!
    Oct 2008
    Indianapolis
    Quote Originally Posted by yellowirenut View Post
    The pic is a little deceiving. The linset only has about 1 inch of dirt on top of it.
    Oct 2008
    Indianapolis
    Quote Originally Posted by trouble time View Post
    Nice clean install.
    The disconnect is from the old unit that I took out. I offered to install a new one but the home owner told me to just use the existing one.
    Jul 2010
    Denver, CO
    It looks real nice, I bet the customer was happy. Why didnt you go straight up and over with the gas pipe, whys it wrapped around the vent?
    Oct 2008
    Indianapolis
    Quote Originally Posted by HuNGRYTeCH View Post
    it just looks that way in the pic it is not wrapped around the vent.
    Feb 2005
    Claremont Ca
    like the van in the backround in the first pic.. rest looks great.
    Nov 2001
    Seattle, WA
    Not a big deal but I always like to see any wire outside going to the condensing unit run such as it causes a drip leg for the rain to run down it so the water hits the ground and not the unit.
    The straight run from the disconnect down to the condensor is going to cause the rain water to follow the line to the unit and collect there, which looks like it's going to be right over the service ports.
    If it's looped down first the rain water will drop down off the lowest point of the loop.
    It's pretty though.
    - Alexis de Toqueville, 1835
    Indiana
    Quote Originally Posted by DeltaT View Post
    It's pretty though.
    guessing he used a pre-made whip. Sometimes you just have to use what is given to you though its not what should be there
    Oct 2008
    Indianapolis
    It's pretty though.
    You mean like this.......Also the discharge line is anchored to the suction line. Pic was taken before that was done.
    Oct 2008
    Indianapolis
    It's pretty though.
    You mean like this. No the bottom of the sealtight isn't over the service valves. The discharge line has been anchored to the suction line. Pic was taken before that was comleted.
    Jun 2011
    Blue grass KY.
    Is that one of them plastic pads? We got away from them do to the problem braking.
