Results 1 to 9 of 9
    Jan 2011
    Some new equipment.
    The Waterfurnace we changed on warranty, so slide one out and slide one in (always sounds easy!)
    2ton 19seer infinity. No I couldn't move the unit to get the disconnect out where it was easy to get to.
    looks good
    suggestion: move the disconnect
    don't know where you are BUT, that won't fly w/NEC
    maybe you have blind or no inspectors
    Jan 2011
    Move it? Rip drywall out and drill a new hole in the brick?
    Jan 2006
    Seattle, Wa
    Quote Originally Posted by jimmyed View Post
    Maybe you could have slid the unit one way or another. Usaully you need 18" in front of the disconnect. Also does that unit come with a drier in the outdoor unit? I think it looks good though
    Lunenburg Masschusetts
    the filter drier is on the inside of the house but is there one located in the condenser also? and i think the job looks neat but i would have slid the unit away from the wall more so u have the clearance to the disconnect and also the necessary air flow that the unit needs i am sure the unit calls for at least 12 or 18 inches away from the building so you get better airflow
    Impressive workmanship!
    Ontario Canada
    Nice looking installs..!
    Never give up; Never surrender!
    if that's the way you want to do it, knock yourself out.
    there are easier ways
    You could have put a juntion box with a couple feet of conduit with a new disconnect attached. Otherwise very clean install.
