Results 1 to 8 of 8
    just got a new 3ton unit installed it replaced a 2.5 ton unit it seems kinda clammy but i might be going thru mid life crisis oh different board anyway got a gauge and its reading 46% humidity with a temp of 75.4 are these numbers okay where i dont need to be concerned about mold and mildew thanks for any info.
    Keep humidity under 60% and you will be fine. Have the evap coil inspected once a year.
    Thumbs up
    thanks alot for the info
    Madison, WI/Cape Coral, FL
    Suggest <50%RH if any carpeting on concrete to avoid condensation/mold between the pad and concrete. <50%RH also eliminates dust mites in upholstered surfaces like beding and carpeting. Pay attention to the %RH during wet cool weather with low/no a/c load. In green grass climates with adequate inflitration/ventilation, 90 pints of dehumidification per 2,500 sqft. of living space maintains <50%RH without any a/c operation.
    This is how the data from a house with a good dehumidifier looks. Had a dry week and followed by a rainy days. No a/c.
    [img]<p><img src="http://www.imagewiz.net/usr/hvac1/21378_rhchart.jpg" [img]
    [QUOTE]Originally posted by teddy bear
    [B]This is how the data from a house with a good dehumidifier looks. Had a dry week and followed by a rainy days. No a/c.
    Trying again. TB
    Tyler, TX
    Why did you go up a half ton?
    RSES Certificate Member Specialist
    Southwest Regional Association of RSES Secretary, 2017
    Midwest
    It's what the auction was for.
