Results 1 to 13 of 14
06-22-2011, 07:59 PM #1
- Jun 2011
- 46
Carrier Model 24ABB360A320, thoughts?
Hi there,
I am thinking about purchasing a 5 ton 410a Carrier Model 24ABB360A320 Condenser. I need to know what inside handler/coil would match this unit. My current inside handler is a R22 system which is hanging horizontal in the attic. I appreciate your time... Much appreciated.
06-22-2011, 08:20 PM #2
- Jun 2011
- 46
Carrier 4-5 ton Horizontal 410 A TXV
Would the above handler match and work correctly?
Thanks again for the advice.
06-22-2011, 08:33 PM #3
Where are you buying this unit and air handler ?
The people you are buying it from should be able to tell / sell you what you need.The opinions expressed by me are not that of my employer.
06-22-2011, 08:53 PM #4
- Jun 2011
- 46
its a neighbors old unit, they replaced it with a heat pump. My coil is a R22 unit, I need to find out if Carrier 4-5 ton Horizontal 410 A TXV Coil will work with Model 24ABB360A320 5 Ton condensor.
Thanks again for your time.
06-22-2011, 08:57 PM #5
06-22-2011, 09:01 PM #6
- Jun 2011
- 46
You are correct, I am not in the field. I am buying the outside unit from a neighbor, he upgraded to a heat pump. The outside unit I am buying from him is only 2 years old. He is only selling me the outside condensor... So I am trying to find the matching coil on Ebay, craigslist, etc...
I found this Carrier 4-5 ton Horizontal 410 A TXV on craigslist...
Sorry for the confusion, your help and advise is appreciated.
06-22-2011, 09:18 PM #7
And who is going to install it?
I am not positive on this, but I don't think the warranty for that 2 year old unit will be valid at your property. Maybe someone else can clear that one up for you.
FYI, anything bought off of Ebay, craigs list, is not covered by any warranty, so if it's defective, or has issues later on you are on your own.
Also most pros wont install anything the customer bought, so that is another thing to consider before you decide to do this.
If your system needs to be replaced, do it properly.The opinions expressed by me are not that of my employer.
06-22-2011, 09:33 PM #8
- Jun 2011
- 46
Thanks for the advice- Much appreciated.
With that said, are the below unit compatible?
06-22-2011, 09:39 PM #9
I am not sure, my company does not install Carrier units..
06-22-2011, 10:09 PM #10
- Jun 2011
- 46
thanks anyways.
Anyone else? are the below unit compatible?
Thanks for the help
06-25-2011, 08:32 PM #11
- Jan 2007
- New Jersey
- 15
AC police
Better watch out JW, it looks like the AC police are hot (or cool) on your trail. Badge #NY2GA01
Mike
06-25-2011, 08:48 PM #12
What size is your current system?
As for the coil, ask the person for the model #.
06-25-2011, 08:56 PM #13
