Results 1 to 9 of 9
    Jun 2011
    Watson, La.
    anyone cook on a plow disc?
    Jun 2005
    Winston-Salem NC
    Almost like a shallow wok.
    Good steel too, not a bad idea.
    Do you have it on a propane turkey cooker ring?
    Jun 2011
    Watson, La.
    it's a small fry setup for a fish fryer, not a very big burner...next project is to replace the burner with a bigger 3-fing burner and lengthen the legs on the frame for a more comfortable cooking height. i don't want too big of a burner because i want to be able to drag food up on the side to stay warm while still cooking in the center
    Okay, I was born in the city. So I gotta ask some questions.
    Doesn't the disc have a hole in the center? What is the diameter ? How thick is it? How did you season it?
    Look neat ! It look like something that would be good to cook crepes on.
    I 'spect it takes a bit of time to season that John Deere Yellow paint offa there...
    But unto the wicked God saith, What hast thou to do to declare my statutes, or that thou shouldest take my covenant in thy mouth? seeing thou hatest instruction, and castest my words behind thee.---Psalm 50:16-17
    Jun 2011
    Watson, La.
    you have to weld a plug into the hole and grind it down. i made mine with a 22" disc. it's about 3/16" thick. i wiped it down with canola oil and seasoned it on the burner, just had to move it around a lot to get the heat to different areas. then i cooked bacon in it and rubbed the bacon all over it
    Quote Originally Posted by shaygetz View Post
    sandblasted it and wiped it down with oil
    Indiana
    I have not seen a plow used in the field for 20 years...its all no till, chisel or cultivate around here.
    For the city folks this is a plow
    The disk portion cuts the earth like a pizza cutter and the plow portion (large curved metal piece) turns or flips the soil over so the top is now on the underside.
    Dry as a bone Tucson
    Plow discs
    Went to a family reunion a few years back in Ruidoso NM. Some of my wifes cousins were from Clyde TX and brought a huge disc with them. I thought to myself what the hell is that thing good for. Well they proceeded to fry up some of the greasiest most delicous burgers for dinner and fried taters for breakfast.
    Mmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmmm
    As you cook the meat all the grease runs down to the middle and you just work the finished stuff up the sides till someone comes along and claims it.
    Some Talk, Some Do
    "I'm just proud to be here."
    Trace Adkins
    Blog
    Web
    Facebook
    Apr 2011
    Im sorry that i had to pay JD over $100 each to replace the disks on my 1953...JD40..restore ..
