Results 1 to 13 of 32
Thread: Carrier Install
    Mar 2002
    Gaylord, Michigan
    First time using Carrier equipment. Happy with the way the a/c came out, but the furnace could have been better. But thought I would post anyway.
    Go ahead, flame away!!
    Apr 2005
    Forgot to put the schreader caps back on
    Mar 2002
    Gaylord, Michigan
    I saw that, luckily caught it before I left the jobsite. I knew someone would see that, it was the first thing I noticed when I upload the pics.
    Going to have to start taking pics of every install, funny what you notice when you are just sitting around, and not rushed.
    Apr 2004
    Bartlett, IL
    Looks good, just wondering why the offset? Looks like new construction, did someone move the trunkline too far over to the left? What size furnace is that? A/C refer lines look good, nice bends, maybe could have been set a little closer to the building?
    Other than the brand looks like a great install!
    Nice work.
    As much as I hate to see duct tape around the linesets (I do it myself) I'm not fond of tie straps either. They are usually pulled too tight and take away from the insulating properties. Before you know it, it breaks through and starts condensating at those points.
    I'm not real big of the "print" on the foil tape. Not sure why they manufacture that style of tape. Is it any different than the plain silver foil tape?
    Was the ductwork fabbed on the job?
    Keep up the nice work.
    Get back to work.
    Jan 2002
    East Grand Forks, MN
    It sure is hard to find good installers!
    I'm glad for my sake that you are not my competitor.
    A very good neat install.
    Questions:
    1. why stay away from the house that far?(A/C)
    2. Why not a better filter system, Carrier's filter media cabinet that come with the furnaces?
    3. Why not a TXV on that wonderful cased coil?
    Mar 2002
    Gaylord, Michigan
    I dont like using duct tape either, been trying to get my distributor to get the black stuff again, but no luck yet. So out come the zip ties.
    The only parts of the metal that were field fabricated were the transition for the supply & at the top of the return.
    The silver tape with lettering is UL681 listed, the unlettered is not.
    The distance from the house for the a/c the answer is ....I dont know. lol. Just used to having to open the back of the condenser to work on it I guess.
    Customer did not want media filter. Just wanted simple one incher.
    Same for the TXV. They splurged on the 2 stage VS furnace, and that was about it for the budget.
    Oh and this was a replacement. Sorry no pics of the before, forgot to bring my camera for the first day. Yeah it took two days, but my helper was not feeling good. So we took our time. Plus it was my first Carrier and I sat on my ass reading the start up destructions for awhile.
    Thanks for all the replies!
    [Edited by christheheatingdude on 09-27-2005 at 10:11 PM]
    Apr 2004
    Bartlett, IL
    Wow that's a replacement, did you install all new returns? metal looks pretty shiny. Thought it was new construction due to the landfill markings on the foundation.
    I think I woulda tossed in a TXV with a VS system, still looks good, nice job.
    Mar 2002
    Gaylord, Michigan
    The home was very short on return air, and the ones that were there, I was not happy with the sizing and the installation of them. So we removed the old ducting, and installed some new returns, and resized all the duct.
    Probably should have included the TXV, but I upgraded him to the better condenser at my expense, just because I like the looks of it better than the builders model.
    Thanks for all the replies, I really appreciate it. Took me awhile to get the nerve to post a pic of one of our jobs. Due to the replies some of the pics on here get. But it is nice to hear what other people have to say, and helps me to strive to make the next one better!
    manitowoc wisconsin
    If you almost forgot the service caps I hope you remembered to torque the valve stem caps down too.Next spring the charge will be low when the rubber o rings shrink & let out the refrigerant from the top of the stems.been there done that ....oops lol
    Take your time & do it right!
    Rochester, MN
    If I recalled, You still can use a 1" filter in those air filter housing, and if the customer wants to upgrade, it's already there for them.
    Otherwise, Looks good.
    What did you use for t-sat for them?
    Rapid City, SD
    Is the chimney for the water heater a lil big with out a furnace now?
    And I'd also like to mention no pookie on the duct/pipe joints. But I also understand on a change out you have to draw a line somewhere. If you pooky your stuff, they'll wonder why you didn't do the old stuff. If you do the old stuff you've just thrown in several more hours of work.
    Awesome looking job though.
