Results 14 to 26 of 49
06-22-2011, 07:07 PM #14
Today I began working on a Spinwave setup we are implementing via Modbus tcp/ip. Seems to work well.
07-05-2011, 08:28 PM #15
- Dec 2007
- 19
07-07-2011, 07:52 PM #16
- Jan 2008
- Front Range
- 33
I have been using the AIC wireless LON transmitter (WLT900) for the last few months with great success. No problems with device discovery,commissioning,upload, download or general operation. I have also been testing the AW5100 Wireless Access Point transmitters utilizing 802.11g/b from from Neteon.net. with great success. I plan on utilizing the AW5100 with EasyIo (Sedona/BacNet IP) controllers to take control of 50 + RTU's on a controls retrofit job. The AW5100 can be utilized to create a 802.11g/b mesh network. I have been skeptical of wireless but have decide there are situations if one puts some thought into the engineering and programing and verifies the site conditions with some field testing it can be a great cost effective alternative to pulling wire.
07-07-2011, 08:23 PM #17
- Dec 2007
- 19
07-07-2011, 09:32 PM #18
How do like EasyIO so far? Have you ever looked at these guys?
http://www.pervasivedevices.com/"If you can't explain it simply, you don't understand it well enough”
Albert Einstein
"Don't you just love when the flames burn off the wiring schematic?" hvacvegas-HTALK member
07-07-2011, 11:47 PM #19
Well my experiment with RIB enocean relays turned into an epic fail. Ended up running underground conduit to the chiller we where controlling. Long story but running conduit was a total PITA.
Had the transmitter inside 4" from a glass window, receiver was 6' away inside a weather proof plastic box and could not get reliable results. The biggest problem (besides the pathetic range) with these is they only send the ON/OFF command once. If it misses, you’re SOL. Stated range is 50', apparently they mean 5". I can’t say anything nice about these parts.
FDI will be getting a nasty call. All the time and service calls I have into this crap, should have ran the conduit to start with.Propagating the formula. http://www.noagendashow.com/
07-08-2011, 09:47 AM #20
I was wanting to do something very similar to your same scenario with these devices. Just wondring, was the transmitter a RIB transmitter or was it some other device?
That really is a let down to hear it can't reliably make it even 6 feet. I was sure hoping that these would work at least that far. In their pdf is says typical range is 50' to 150'! Did you ever talk to anyone at FDI about the poor range?"If you can't explain it simply, you don't understand it well enough”
Albert Einstein
07-12-2011, 07:52 PM #21
- Jan 2008
- Front Range
- 33
Xarralu,
I have been bench testing the LYX-30P (This is Lynxsprings version of the EasyIO 30P-SF) and have been happy with it. It showed up in a plain cardboard box with no documentation, software info, driver info or installation instructions but that being said knowing it was a brand new product for Lynxspring I contacted there tech support and before the end of day I had it configured / online and had started programming it. It seams to be a pretty robust programmable controller with lots of diversity with the configurable IO and choices of protocol options (Sedona , BacNet IP, Mstp and Modbus) and priced right. Also the best info and training material for EasyIo is found on a series of Youtube videos. Start here . On a side note I’m very interested in this Sedona wireless product if it is priced right and works as advertised (really cool).
07-12-2011, 10:23 PM #22
Both sides where the RIB parts. The transmitter was the 24v model and the receiver was the 110v relay. Initially they where installed about 30’ apart with a masonry between, never worked. Managed to find a hiding spot next to a window that was directly in line with the receiver and relocated the transmitter.
I talked with FDI on during the initial setup, as pairing the two modules was not totally clear in the documentation. Their tech made mention that they really needed to be close when initially paring the two. I thought this was odd because it would not work @ 6’ which should have been fine according to the documentation.
After spending the time installing them twice now, and the service calls to figure out what the problems was, I decided to cut my losses and hardwire the unit. Once I get the parts back, I’ll be getting in touch with about returning.Propagating the formula. http://www.noagendashow.com/
07-12-2011, 11:58 PM #23
That is cool! Their wireless IBO vav controller look cool also. I think if I was going to jump into a line, EasyIO or something with Sedona looks like the way to go.
I really wanting to get some wireless hardware in my hands and give it a real world test drive. Haven't really heard anyone fully implementing Zigbee or something like it, but I've been thinking fork over some of my stash and get some "stuff" to try out.
Enocean sounds like its really getting off to a bad start/run. I haven't heard one person say anything good about it at all.
Anyways, thanks for the info Debug. One of the places I get parts from has a few EasyIO controllers in stock, I might just have to pick one up."If you can't explain it simply, you don't understand it well enough”
Albert Einstein
07-13-2011, 12:25 AM #24"If you can't explain it simply, you don't understand it well enough”
Albert Einstein
07-13-2011, 08:43 PM #25
- Dec 2006
- Boston area
- 159
How about the Viconics wireless? Have a job coming up using them. Any one use them?
07-13-2011, 09:53 PM #26Propagating the formula. http://www.noagendashow.com/
