Originally Posted by
orion242
Both sides where the RIB parts. The transmitter was the 24v model and the receiver was the 110v relay. Initially they where installed about 30’ apart with a masonry between, never worked. Managed to find a hiding spot next to a window that was directly in line with the receiver and relocated the transmitter.
I talked with FDI on during the initial setup, as pairing the two modules was not totally clear in the documentation. Their tech made mention that they really needed to be close when initially paring the two. I thought this was odd because it would not work @ 6’ which should have been fine according to the documentation.
After spending the time installing them twice now, and the service calls to figure out what the problems was, I decided to cut my losses and hardwire the unit. Once I get the parts back, I’ll be getting in touch with about returning.
It will be interesting to see what they tell you. If they give you any grief about returning them, you could sell them to me.
"It's not that I'm smart, it's that I stay with the problem longer”
Albert Einstein
