Page 1 of 4 1234 LastLast
Results 1 to 13 of 49
    Wireless Control and Systems Integrators
    Have you used EnOcean wireless devices? They are the battery free and get their power from the energy surrounding them.
    If you have used them I would like your feed back. If not would you like to know more?
    Jan 2003
    I have used the RIB relays that use EnOcean.
    Both sides of the link where battery free, as they required 110 or 24v
    Short story, I was not impressed.
    May 2002
    I have had extremely poor results with EnOcean room sensors.... with or without battery.
    NY
    I tried an EnOcean room sensor with and without battery and frankly it was a total waste of money.
    I'm not sure whose technology Trane uses but I have had amazing results with their wireless receivers and sensors, and at half the cost of the EnOcean product.
    "Controls is a lifestyle not a job" -klrogers
    Feb 2005
    ditto.
    Jan 2003
    Well seems like we are all and the same page and will 'run more wire'
    LOL
    In my service van checking my lotto ticket
    Quote Originally Posted by orion242 View Post
    LOL
    Well majority says enocean sucks, but has anyone had any luck with Zigbee or something like it?
    "If you can't explain it simply, you don't understand it well enough”
    Albert Einstein
    "Don't you just love when the flames burn off the wiring schematic?" hvacvegas-HTALK member
    On Monday, not even the chickens lay eggs...
    Jan 2003
    I had good luck with BAPIs wireless gear.
    Yea we have too. What about wireless for module to module comm?
    Albert Einstein
    Jun 2009
    StL, MO
    I've had good luck with Honeywell's TR21/23WK modules. The only "trick" to using them is connecting the earth ground.
    UA LU 562
    Quote Originally Posted by DaveCR View Post
    Earth ground meaning for the receiver?
    Albert Einstein
    Jan 2003
    Have not used much more than industrial WIFI gear in a few places. For comms we stick with wire, if need be we can bring in the I/O wireless to the module. I would be all ears if someone has used some sort of wireless MS/TP gear. I have a feeling that the latency would torch the network at all but the slowest bauds.
    Jun 2009
    StL, MO
    Quote Originally Posted by xarralu View Post
    Yes.
    UA LU 562
