Page 1 of 4 1234 LastLast
Results 1 to 13 of 41
Thread: EASYSEAL!!
    EASYSEAL!!
    Has anyone had any problems using this product? I'm told this stuff will repair most small leaks in evaporators, condensers and fittings. It seems to be too good to be true so I would like to to hear opinions from other users.
    Houston,Tx.
    Quote Originally Posted by RAZORJ View Post
    It seems to be too good to be true .
    So what does this tell you?
    __________________________________________________ __________________________________________________ _________
    "The critic is a prisoner to his own experiences and perspectives, erroneously believing his limited experiences are the sum of all truth".
    Northeast Ohio
    While it may seal leaks, it may do other things as well. No necessarily good things. It reacts with moisture soooo............................................. depending on the condition of the system
    Mar 2006
    Denver/Boulder
    Ahhhh.... yea.
    Let us know when it stops running.
    What lies behind us and what lies before us are small matters compared to what lies within us.
    Two pressures, four temperatures = SUCCESS!
    Boulder Heating Contractor
    As a matter of fact my TXV locked-up on me. I am running system like a cap tube untill I can replace TXV. Not happy camper. Salesman said best thing since sliced bread. Fool me once--shame on you--fool me twice shame on me.
    No free lunch
    Jun 2011
    Puget Sound area, Wa
    I've seen this stuff plug the leak but it also plugged the metering device. Not a fun repair at all. I was always taught to never put anything in the system that wasn't put there by the manufacture. I didn't use the leak seal in case you're wondering it was someone else, I was just involved with the return call.
    Thanks for your input.
    Mar 2006
    Denver/Boulder
    No problem!
    Always trust the Duck.
    SE Michigan
    I used it for the first time about a month ago after leak checking a system and not being able to find it. There is about 30 feet of the lineset hidden in a ceiling that I cant get to.
    I put in a can of this snake oil...so far, no problems.
    "If anybody can draw on the power, where do we put the meter?" - JP Morgan before pulling Tesla funding
    May 2008
    Missouri
    It worked great for us as long as you "really" wanted to replace the entire system in the first place because that's what eventually happened. I think now they have a complete "kit" containing another additive (or two) you have to use in a certain order but based on our experience, I'd never touch that stuff again (unless you want to replace the entire system). Used it four or five times, with simply bad results each and every time.
    Jun 2011
    Wake Forest, NC
    I used it when I was in maintenance and the idea was to extend the life of equipment at any and all costs\ (even if there was a 90% chanceit would kill the equipment), but would never, i repeat NEVER sell this stuff to a customer...
    Unless I really didnt like them...
    Or wanted to force them to replace their HVAC unit in the next two weeks...
    May 2008
    Missouri
    Hmm
    Last time we used it, we decided to "really" make sure system was dry. It was a 12 yr. old GSHP with small leakage in indoor air coil (evap). We pulled the charge, and replaced filter dryers and ran system for about 2 weeks, then went back and replaced the dryers and then added the sealer. This GSHP actually ran about 5 weeks before the compressor seized up. It was TWICE as long as we had one last before, but in the end it killed the patient anyway!! The stuff sounds good, but as mentioned before.....sounds too good.
    Mar 2006
    Denver/Boulder
    Quote Originally Posted by wahoo View Post
    Just curious...
    Why not fix the leg instead of killing the patient?
