Thread: CGAF evap
    tidewater, va
    CGAF evap
    What are you guys cleaning the plate frame heat exchangers (evaps) in the newer CGAFs with?
    r404a
    Jul 2001
    maryland
    Sulfamic Acid AKA orange juice
    Saving the world...one service call at a time.
    SouthEastern Virginia
    Minute Maid or Donald Duck?
    It might get loud!
    Jan 2005
    Houston TX
    Flushing the toil....evaporator I mean
    R-404a- Not sure if that one has a strainer in the internal piping before the plate heat-x like Carriers, but if it does I remove it and clean it, then I reverse flush out the the heat exchanger and watch what comes out. Those flat plate heat-x's on both Carrier and Tranes are real catch-alls and will freeze up quickly if not maintained and flushed out regularly- GEO
    Once in a while everything falls into place and I am able to move forward, most of the time it just falls all over the place and I can't go anywhere-GEO
    Dec 2008
    Dixiana, AL
    RydLyme works well.
