I have a gas fireplace. It's easy to tell if the chimney damper is closed/open because you can SEE the damper.
There's another damper; I think it feeds outside air to the gas logs. Can't see the damper itself; there's no label of any kind on the damper handle. With this kind of setup, how do you know if the damper is open or closed ??
