Results 1 to 8 of 8
    Mar 2011
    Abilene Tx
    Poor high voltage connection
    Had a call that a chiller was down. Opened up panel to find the wires all burnt up. You can see how the wires were sort of twisted around each other. That was the way I found it, with some electrical tape hanging off of it. It was 1 gauge wire coming in the top of the compressor contactor. A 60 ton compressor, 480 volts by the way. I guess the guy didn't have long enough wire and had to make a quick fix! Not safe, for sure.
    it's always scary to open a panel and see crap like that,
    Dec 2010
    Woodbridge Twp, NJ
    Makes you wonder what other "fixes" the guy did.
    Hey boss, the purge unit on the absorber was leaking so i brazed it shut..no need to thank me!
    Every customer you take for granted today will be someone else's tomorrow.
    Jan 2003
    whaooo look at the pretty lights....
    Propagating the formula. http://www.noagendashow.com/
    Mar 2011
    Abilene Tx
    Man, let me tell ya. It's been three or four months already and it still has "that" smell inside the panel.
    I had my head inside a 4160v primary reactor starter panel the other day that failed to transition to run and subsequently burned out the reactor... That was a smell I would like to soon forget.
    May 2010
    Lake Stevens, WA
    Hmmmmm
    Things that make you go hmmmmm..........
    Afton, VA / Khorat, Thailand
    Even sparky has a Friday party to get to I guess......
    Midnight Sun Astrophotography
