Results 1 to 13 of 19
    Need A New Fieldpiece Multi Meter Any Sugestions?
    My Multi Meter Is About To Give Up The Ghost And I'm Looking For A New One! I Have A Fieldpiece LT-17 Meter That I've Had Forever And Would Prefer A up Grade From That! What Is The Best Fieldpiece Meter Out there That Read Milli Volts As Well As Capacitors And Dc Voltages?
    SE Michigan
    Fluke!
    “Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery.”
    Fluke X 2
    Feb 2011
    Cloverdale,Ca
    I use a HS-36 and it works for me. Millivolts, microfarads, dc voltage, temperature, VAC, Ohms, backlight, and a magnet. I would suggest the Amp Clamp attachment as mandatory. I am sure Fluke is great, I just have never owned one.
    Apr 2005
    Central California
    Fluke!
    A fieldpiece is like one of those weedeaters you see at home depot. It will cut grass, paint your house, wash you car and whatever else you need it to do as long as you spend a pile of money on the attachments. I know you didn't need my opinion but I was bored
    Only Chuck Norris can slam a revolving door
    May 2010
    Canada
    Look into the sc56 and the hs36 if you want to stay with fieldpiece.
    hs36
    http://www.fieldpiece.com/stick-meters/hs36
    sc56
    http://www.fieldpiece.com/clamp-meters/sc56
    SC77 is auto ranging w/ backlight.......got that one, SC76 no backlight
    SC66 still use that one mostly
    SC64 use it occassionally
    the 66, 76,77 will do all you want
    and for the pec*******
    I've never had to spend a penny on any of the Fieldpiece instruments I've got
    and I've had them for years
    May 2010
    Canada
    Quote Originally Posted by dandyme View Post
    dandyme is probably right in saying the sc77 will most likely do everything you need in a meter. I think that if you want some extra features you should look at the hs36 and the sc56 as well.
    The sc56 is the best all around clamp meter that fieldpiece offers. The hs36 is the best stick meter fieldpiece has to offer.
    The sc56 does not have probe storage like the sc77 and the hs36 , but can do inrush current, %duty cycle and diode test while the others do not. I believe the sc56 can also has a multi display so you can show amp draw and voltage at the same time.
    just select the meters you want to compare
    http://www.fieldpiece.com/products/compare-multimeters
    houston, texas
    SC 77 you will be a happy camper.
    I'm not tolerating Political Correctness anymore, from now on it's tell it like it is.
    Veto Pro Pak - The best tool bag you'll ever own
    Atlanta GA area
    These are the two meters I like.
    GA-HVAC-Tech
    Aug 2010
    The - SSX34 is by far the best tool in my bag for quick checks better then sex some would say.
    Quote Originally Posted by ga-hvac-tech View Post
    high quality techs have high quality meters
    Fairfield county Connecticuit
    Fluke x3
