Results 1 to 12 of 12
    Jun 2011
    Santa Ana CA
    Confused Question on a test
    Yesterday I went for a job interview and on the test there was this question. your working on a 5 ton package unit 208 single phase the wires are pulled off the compressor the cap is gone and no wiring diagram how would you determine witch terminal is start, run and common. If someone knows the answer please let me know
    Arizona
    Quote Originally Posted by respectable001 View Post
    CSR, read it like a book. Start at the upper left, read left to right and then down.
    Make your expertise uniquely valuable.
    Make your influence uniquely far-reaching.
    Jun 2011
    Puget Sound area, Wa
    Run to Common=lowest ohm reading
    Start to Common=higher than R to C
    Run to Start=equal to the above 2 readings
    Dec 2010
    new jersey
    the easiest way....is to look in the comp. terminal cover.lol
    Arizona
    Quote Originally Posted by sprmktrefertech View Post
    That would be cheating! LOL
    in my lumpy chair
    Quote Originally Posted by johnbeck1000 View Post
    good job.
    why haven't you applied for pro yet?
    I dont warranty Tinkeritus
    Jun 2011
    Quote Originally Posted by lolson View Post
    good job.
    Well I needed more than 15 post and then I felt like a homer because I don't have very many certifications to put up. I've got an EPA one and journeyman certificate but is that enough? My company doesn't send any of their techs to any factory training so we don't get certifications. They send guys who install but not the techs, which doens't make much since to me since we fix the stuff when it fails. I've gone to classes I can afford or they will pay for but I can't afford factory training on my own.
    Mount Airy, MD
    You got enough, send in your app
    Jun 2011
    Quote Originally Posted by Chris_Worthington View Post
    will do
    in my lumpy chair
    will do
    Getter done. LOL
    Jun 2011
    Santa Ana CA
    question on a test
    thanks for your input,i thought i was on the right path i put down with your ohm meter but i couldent rember the values .THANKS
    or the foam seal
    Quote Originally Posted by jimj View Post
    no it's not
    bet it would have busted their bubble to see that answer though
