Did you determine the eratic oil pressure from a seperate gauge, or just the operation of the unloaders ??
Have you examined the unloader gasket (usually a stamped metal one) to see if there is evidence of blowby ??
Noisy unloaders are common, but erratic oil pressure is not. Remove the unloaders from the equation, then take an oil pressure reading, it should narrow down your focus
