Results 1 to 7 of 7
    Mar 2010
    charging calculation formula
    what is the charging calculation formula used when 25 feet pre-charged line set R-22 is extended to 50 feet ?
    how much more refrigerant needed to the additional 25 feet line set without refrigerant in it ?
    What type of metering device?
    What are the indoor conditions, outdoor conditions?
    Type of refrigerant doesn't matter.
    Arizona
    Not to mention what is the line set size!
    Make your expertise uniquely valuable.
    Make your influence uniquely far-reaching.
    Mar 2006
    Denver/Boulder
    Sorry, panaboro.
    No DIY help to non pro members.
    Read site rules and apply for pro status if you qualify.
    What lies behind us and what lies before us are small matters compared to what lies within us.
    Two pressures, four temperatures = SUCCESS!
    Boulder Heating Contractor
    For Consumers:
    For HVACR Professionals:
    Mar 2010
    Quote Originally Posted by panaboro View Post
    3/8 liquid and 7/8 suction with TXV. there is no mention indoor/outdoor condition. but i guest will be standard design temperature 95*outdoor and 75* indoor 50% RH
    I had a test question a month ago that i can't find the answer in my book.
    thanks
    Mar 2010
    I want to find the answer for a test question i had a months ago.
    i can do subcooling or superheat but its a test.
    thanks
    I'm sorry, I misread the question.
    This is actually a queston regarding the volume added to the lineset and the density of the refrigerant.
    The BEST way to correctly charge a unit is to use superheat or subcooling depending on the metering device.
