    Mar 2010
    A/C with Hydronic heat and economizer question
    what kind of sensor or device necessary to be use, when A/C with hot water heat and economizer is installed ?
    Depends on he set up.
    Mar 2010
    Quote Originally Posted by panaboro View Post
    what kind of sensor or device necessary and must be use, when A/C with hot water heat and economizer is installed ?
    I mean for air mixing or sensor purpose where hydronic unit with economizer to operate. i guest there is mixing sensor or something needed.
    is there a special sensor or devise must be use that different then gas or electric heater ?
    i have no experience with AHU with hydronic and economizer.
    thanks
    A few things are slightly different. Need to protect the hydro coil from freezing.
