Results 1 to 11 of 11
    Feb 2007
    ont. can
    looking for a 180 degre bender
    hello....im hoping to find a 180 degree tube bender
    im located in ontario and would appreciate any help locating one
    thanks
    Jun 2011
    Have you tried looking at a local supply house or maybe e-bay.
    Sep 2009
    S.C.
    Buy a Spring. No, you didn't give the size but a spring bender will work.
    Yes, I know I Shouldn't But I Just Can't Help Myself...
    Spring bender will work.
    Best bender I've tried is the Yellow Jacket ratcheting bender.
    Pricey, but damned effective.
    Feb 2007
    ont. can
    i need a bender that will do 3/8 to 3/4...... ive never used a spring bender. would it work on 3/4 ebay has only small diamater ones .....a decent canadian wholesaler maby
    Jul 2001
    Canada
    Heres one to look over http://www.buytools.ca/index.php/con...ng-bender.html
    Princess Auto has them as well, not sure about 3/4" might have to check with 1 of SPECIALTY places.
    May 2010
    Oxford, UK
    Have a look at the Rems Sinus bender, a bit pricey but does do very nice bends, also you can use the formers on the powered bender if funds allow an upgrade in the future.
    May 2011
    Ontario, OR
    I too recommend the Yellow Jacket ratcheting bender. I'd be lost without mine.
    Sep 2009
    S.C.
    Quote Originally Posted by Baloo2327 View Post
    The OP is wanting to bend a 180 degree bend. (That's a "u".) I also have the Yellow Jacket Bender but to my knowledge it will not bend a 180.
    I've had cases where I needed two bends close together and had to use a spring.
    I don't know how some Tech's get by with a Swaging and Bender Set.
    Quote Originally Posted by Control Man View Post
    That one never crossed my mind. I have one somewhere.
    May 2011
    Ontario, OR
    [QUOTE=Home&Marine;10501502]The OP is wanting to bend a 180 degree bend. (That's a "u".) I also have the Yellow Jacket Bender but to my knowledge it will not bend a 180.
    LOL! I know what kind of bend the OP was talking about, and I've done a couple with the Yellow Jacket bender. You just have to be a little creative on how you use it, and work it around. Watched too much McGyver, and live in a farming community.
    Mar 2011
    check out imperial eastman refrigeration tools
    they have a lever bender for 1/4 5/16 3/8 1/2 that will do a 180
    as well as many other lever benders up to 7/8
    they also have a bench mount worm drive gear bender for production work
    i use the 180 feature on mine to duplicate factory style discharge line vibration loops
