Results 1 to 2 of 2
    Jun 2011
    Suction line sizing
    Would someone be kind enough to answer question ...I am having a 5 ton coil R22 aprox. 57 feet from condenser to coil.. Condenser is ground level coil is 20 feet higher ... What is prefered diameter of suction line ..7/8 or
    1- 1/8 ?? Is there an advantage to go next size higher or not.. Some manuals list 7/8 as minimum ...others as 1 1/8. Your thoughts Please?
    Feb 2007
    Helena, Montana
    They might answer if you ask it in the appropriate area instead of one that says, in bold red letters, "DO NOT POST QUESTIONS HERE".
    Don't worry zombies are looking for brains, you're safe...
