Results 1 to 12 of 12
Thread: Need HELP with Excel
09-21-2005, 03:10 PM #1
If you have a spreadsheet, and you've typed in a half page of text below it, how do you get rid of all of those #%$@ boxes the text is in? It's a real pain editing the text in those boxes!
09-21-2005, 03:27 PM #2
- Nov 2004
- Atlanta, Ga. burbs
- 281
Open up Excel and do this:
Tools
Options
View and uncheck the gridlines
09-21-2005, 07:48 PM #3Thanks. I did that, but IT'S STILL A PIA TRYING TO EDIT THE TEXT!Originally posted by west_seth
Tools
Options
Is there a way to make a block of text be in one giant cell?
09-21-2005, 08:03 PM #4
- Feb 2004
- 1,005
Select a group of cells (boxes) that you would like to merge into one big box. You proably know but you do this by holding the left botton down and draging it over the area.
Now select Format, cells, and click the "Alignment" tab. Check the "Merge cells" box.
You may also want to check the "Wrap text" box.
09-22-2005, 07:33 PM #5Originally posted by nevada
I tried that, but this is how it came out.
It took a block of text made and made one big cell the size of the block of text. Then it warned me that it was all going to be merged and that only the top would be there, and it didn't lie. Only the first line of text showed up.... at the bottom of the big cell.
09-22-2005, 09:29 PM #6Could you just do me a favor and tell me what theOriginally posted by outside rep
yes up top on the right side there is a little box
[--] that looks kind of like that
Left click and high light the whole area and click that button and that will make the whole area one big cell
"little box [--] that looks kind of like that"
says when you hold the mouse over it.
09-22-2005, 10:35 PM #7
Grumpy Old Man
- Apr 2003
- 6,383
Mine goes from left to right....
align left, center, align right, merge and center.
09-22-2005, 11:18 PM #8
I was using the "merge and center" command before. It gives me the message:
"Merging into one cell will keep the upper-left most data only"
then it deletes all but the top.
I found out that it's a bug in my 97 version of Excel:
SYMPTOMS
In Microsoft Excel 97, no "Center Across Columns" button appears on the Formatting toolbar. In its place, a "Merge and Center" toolbar button appears.
Back to the top Back to the top
WORKAROUND
Although the "Center Across Columns" toolbar button is no longer available, you can still center text across columns without merging cells. To do this, use the following steps:
1. Select the range of cells over which you want to center text.
2. On the Format menu, click Cells.
3. Click the Alignment tab.
4. In the Horizontal list box, click "Center Across Selection."
5. Click OK.
STATUS
This is by design of Microsoft Excel 97.
MORE INFORMATION
The "Merge and Center" toolbar button in Microsoft Excel 97 provides a level of functionality that is very similar to the functionality provided by the "Center Across Columns" toolbar button in earlier versions of Microsoft Excel. Basically, the button allows you to center information contained in a single cell across a range of cells.
Note that there are some minor differences in behavior between the two buttons. The following examples illustrate these differences.
Examples
Assume that you have a new worksheet in Microsoft Excel that contains the following information:
A1: test
A2: hello
In Microsoft Excel 97, if you select the range A1:E2 and click the "Merge and Center" toolbar button, the entire range A1:E2 is merged into a single cell. The word "test" appears centered within this cell. In addition, because merging cells removes the contents of all cells within the range except for the upper leftmost cell, you will receive the following message:
The selection contains multiple data values. Merging into one cell will keep the upper-left most data only.
Clicking OK results in the deletion of the word "hello," and the merging of the cells. Clicking Cancel cancels the merge and center process.
If the other cells in the range must retain their own contents, or if you need to center multiple rows of information, use the workaround shown above to format the cells with the "Center Across Selection" alignment.
The problem is, the "workaround" of using "center across columns" doesn't merge that data.
So it looks like checkmate.
09-23-2005, 01:35 AM #9
you have an out its called upgrade by your ever so friendly microsoft company microsoft office excel 2003
www.vetopropac.com - The best tool bags on the market - The offical tool bag of choice by techs everywhere
Arguing with some people is like wrestling a pig - eventually you realise the pig actually enjoys it
Gonads serve a useful purpose but are no substitute for brains
09-23-2005, 07:28 AM #10
- Feb 2004
- 1,005
The text that you have type in the cells will not all merge even with Excel 2003. Make the larger cell that you want and retype the text. Another option instead of selecting cells on mulitple rolls is to merge as many cells as you need on only one row and changing the row height for that row.
Send me an email. I have something that will fix your 97' problems. I can't mention it here because this thread would then surly beat out the 9mm one causing Dice to have a heart attack and HVAC-Talk as we know it will not longer exist.
09-23-2005, 12:33 PM #11
I No Longer Have Excel
Unless I want to pay for it, and I aint doing it.
I pray not for an easy life but that I be a strong person.
09-24-2005, 07:21 PM #12
- Nov 2004
- 146
a word to the wise. dont send your email address unless you have a good spam program
