Page 4 of 5 FirstFirst 12345 LastLast
Results 40 to 52 of 55
  1. #40
    Aug 2005
    LMAO. He just said nevada, btexpress, and anonymous have small weinies.
    Mrfrio - certified hvac-talk translator.
  2. #41
    igwt777 is offline Professional Member - T&B bad email address
    Jul 2005
    Definitivamente hacia falta un traductor certificado por HVAC-Talk.
    LOL!!!
  3. #42
    Jul 2003
    Talking
  4. #43
    Only Workhorse sits around thinking about the sizes of other men's dicks.
  5. #44
    Fort Worth, TX
    Mi nombre en español traduce para hacer compras persigue. Trabajo en refrigeradores. Los refrigeradores en español agua fresca todavía como refrigeradores ingleses . ¡Sin embargo, los refrigeradores que tengo hablar inglés!
    Building Physics Rule #2:
    Building Physics Rule #3:
  6. #45
    Jul 2003
    My name in Spanish translates to make purchases persecutes. Work in refrigerators. The fresh water refrigerators Spanish still like English refrigerators. Nevertheless, the refrigerators that I must speak English!
  7. #46
    Fort Worth, TX
    LOL!
    You must've found the same translator I did. (Google)
    Actually, what I submitted for translation was:
    My name in Spanish translates to shop hound. I work on chillers. Chillers in spanish still cool water like English chillers. However, the chillers I have speak English!
    [Edited by shophound on 09-25-2005 at 11:24 AM]
  8. #47
    Jul 2003
    No, es realmente el que esta' de AOL. Cualquier manera todos hacen básicamente la misma cosa.
  9. #48
    Fort Worth, TX
    Google translation: No, he is really the one that is of AOL Any way all make the same thing basically.
    Ci mon!
  10. #49
    Jul 2003
    Try this.
    Go to the translater and type something it to be translated. go from english to spanish to english to spanish and back to english. It really screws it up.
  11. #50
    Fort Worth, TX
    Try this.
    Here's your sig line run through the Google translation mangler:
    ¡Si usted no puede manejar el calor, llame a su competidor!
    If you cannot handle the heat, calls to your competitor!
    ¡Si usted no puede manejar el calor, las llamadas a su competidor!
    If you cannot handle the heat, the calls to your competitor!
  12. #51
    Translators only give you a general idea of what is said. Not good for commnuicating.
  13. #52
    Nov 2000
    Eastern PA
    Cogida apagado, usted idiota. ¿Cómo está eso para transliteral?
    ...seek, and ye shall find;..
    Ecclesiastes 10:2 NIV
