Results 1 to 13 of 15
Thread: Trane Rtu
    Brooklyn, Ohio
    Trane Rtu
    I am working with a Trane Rtu M/N YCH150C4LOAB..S/N L06104. Customer wants to replace the zone sensor with a programmable thermostat.The existing sensor is a BAYSEN008B. I have no wiring diagram so I am not sure how to connect a 24 v thermostat and if its even possible. The sensor wires are wired to terminals 1 2 3 4 5
    Any insight would be appreciated.
    if ti doesn't have one, you'll need a Conventional Thermostat Interface board
    then it's just like any other t-stat
    You need to get a conventional thermostat interface board to be used with any 24v thermostat or get a Trane programmable thermostat like a BAYSENS019B.
    Apr 2010
    Minnesota
    Get the 24v interface. 019B sucks IMO.
    Jun 2009
    ontario cali
    ucp board on unit?
    Indiana
    Quote Originally Posted by dandyme View Post
    X2
    they pop in rather quickly
    Southeastern Pa
    Yes.
    Install the CTI. It's not expensive, and you can install any quality thermostat, like a vision pro or focus pro.
    Dec 2009
    Fort Worth, Texas
    do the reliatel boards use 0-5vdc for control from the sensors. the reason i am asking i have a customer that wants to incorperate the existing control system to these units. i know you can install a cti and use a control with relays but if they use a 0-5 vdc or 4-10 ma then i can forgo the cti and just install a flex stat or reliable sse.
    thanks for any info
    Hampton Roads, Virginia
    Quote Originally Posted by HJ Controls View Post
    thanks for any info
    See attached pdf, pages 46-49 gives you information on the sensors.
    Also if you have the Reliatel board you do not need a CTI board to install a regular thermostat (or relays from another control system).
    Kevin
    "Profit is not the legitimate purpose of business. The legitimate purpose of business is to provide a product or service that people need and do it so well that it's profitable."
    James Rouse
    Southeastern Pa
    Quote Originally Posted by klrogers View Post
    Kevin
    Yes.
    The Trane folks incorporated a standard thermostat interface into the ReliaTel board. The CTI is only needed when using the older units that use the UCP board.
    The UCP has a red LED in the lower left hand corner, and the ReliaTel is a far smaller board, and has a green LED that is not in the lower left hand corner.
    The ReliaTel "conventional" strip is marked with the typical Y1, Y2, etc, and is located along the edge of the board.
    it's not a precedent
    yh is precedent
    Dec 2009
    Fort Worth, Texas
    ok then these units have the ucp. there about15 yrs old
    Aug 2005
    iowa
    personally in my opinion i would not waste my time installing a CTI. by the time you install the board buy a high end thermostat and then pull new tstat wire you have wasted money.
    now you may not need knew wire, but if it is multistage you will. also the cti eliminates things like one compressor below 55 degrees, and a whole assortment of features that i cannot think off and i dont have the manual in front of me.
    in my opinion i would get a trane programable and be done with it.
    jeep
    geez!!! the more i learn the more i know i need to learn!!
