Results 1 to 11 of 11
    I'm looking for any technical information on an older Lennox forcedair gas furnace, model G803-105-1. Any technical information, schematics, installation info, etc. would be greatly appreciated.
    Apr 2004
    Bartlett, IL
    Looks like a 105K btu furnace.
    LONG ISLAND, NY
    G80Q-3-105--3Ton drive,105K
    G8 furnace model
    Q3 is the 3 ton drive
    never seen a 105, usually 100
    -1 series #
    chgo berbs
    105 is the right btu
    I don't know
    55% to 60% AFUE when new, slightly higher if it has electronic ignition. Up to 70% if a damper was installed.
    shouldnt that have a split HX on it by now?
    burlington county n.j.
    damper and ignition not even available on G10, doubt they were available on this old beast.
    I don't know
    Some of the G8s aren't that old; they built them in Canada until '91/92 when the 78% minimum went into effect. The newer ones have electronic ignition - not sure about the damper though.
    damn Amd your right! did not have parts program at home when i said they did not have spark ign. davenet did not show it but parts program does. forgot you guys up there had stuff longer. don't think i have ever seen one made after very early 70s.
    I see alot from 88/89 and condemn most of them
