    May 2011
    Chas.,WV
    Hobart dishwasher
    Does anyone know the value of the thermistor for the wash tank heater at 160F and / or the board check out procedure? The model is C44AW.
    Nov 2007
    central Nebraska
    It has been a few years but I thought that thermistor topped out at 199 degrees (2500 ohms rings a bell).
    Is that the model that routes the thermistor wires thru a conduit at the back of the control panel on top into a splice box about knee-high before it connects to the thermistor? When I worked for Hobart, I had one that had an intermittent connection in that splice box. It drove me nuts trying to figure out why it worked just fine when I was there, but it would not indicate the next day.
    Hope my ramblings help you,
    Rick
    May 2011
    Chas.,WV
    Thanks Rick , good suggestion . The thermistor is located there. Unfortunately , I disconnected at that junction and still have a reading of infinity.
    Nov 2007
    central Nebraska
    Sorry that I could not help you.
    I don't know if Hobart will give you that value unless you agree to buying a brand new thermistor.
    Is there another C44AW in your customer base that you can check the value against? It has been almost 5 years ago that I left Hobart, but I thought that thermistor was the same on the AM-14 as well as the Conveyor dishwashers.
    Good luck,
    Rick
    Over the river and through the woods
    approx. 14,800 ohms @ 160 degrees. 100,000 ohms @ room temp (77 degrees)
Quality Home Comfort Awards
