Results 1 to 9 of 9
06-14-2011, 02:53 PM #1
New Guest
- Jun 2011
- 4
Heat Pump Unleveled - see picture - is it a problem?
Just had a new system installed. Just after the installers left I noticed the compressor is unlevel by about just under an inch. I've attached pictures, should I get them to fix this or is it not enough to matter?
Thanks in advance!
06-14-2011, 03:11 PM #2
Professional Member*
- Apr 2007
- Langley, BC, Canada
- 371
Does it bug you??? I know it would drive me nuts...get them to come back and level it properly.
*Proud To Be a Member UA LOCAL 516*
***GO CANUCKS GO!!!***
06-14-2011, 03:15 PM #3
Simple fix for them and it would not greatly effect the operation of your system, other then creating some uneven wear for the fan motor and compressor after years of operation.
"I" would have them fix it, but I would also know that as the ground settles,,,,, there goes the level bubble
06-15-2011, 01:42 AM #4
- Nov 2010
- Central Florida
- 527
Comment and question:
Why is the unit not mounted on the pad directly? Is this due to some kind of weather-related concern such as snow or water?
Glancing closely at the photo it seems to appear the unit might be out of level not from just the pad but more from the "lifters".
Sonic
06-15-2011, 02:15 AM #5
- Apr 2010
- 21
Also looks a little close to other condenser, makes it difficult to service either one.
06-15-2011, 11:38 PM #6
- Nov 2010
- Central Florida
- 527
Just a suggestion: Why don't you take a picture of the level on the PAD itself, that way you can get a visual to compare which is slanted, the pad or the condensor, or both.
06-15-2011, 11:46 PM #7
06-16-2011, 12:25 AM #8
- Jun 2011
- Muncie, Indiana
- 224
06-16-2011, 12:27 AM #9
