Results 1 to 2 of 2
    Atoka, TN
    Help on 19XL5758493CR
    no Benshaw starter, I get a Low Line Voltage Dropout after 1 hour of operation. Cooling normal and have to do a manual restart. I have checked line voltage and low pressure switch as OEM stated, checked for loose wiring, all are tight. Any suggestions? Thanks in advance for any help, i have been fighting this problem all weekend and I am getting nowhere.
    Dec 2010
    I know you have probably solved this by now. As strange as it may seem I
    have seen loose solder connections on 6-pax relay board cause this and other
    similar prolems.
