Results 1 to 7 of 7
    Apr 2011
    Unhappy YAEP CHILLER AGAIN
    PLEASE ANY ONE HAVE A PARTS CATALOGE FOR YAEP CHILLER
    AND PLEASE ANSWER ME ABOUT THE PROBLEM IN THE BELOW THREAD
    THE CHILLER FAILED HIGH AMBIENT ALTHOGH ITS NEW AND ALL VALUE ACTUALY CORRECT
    I WAIT THE ANSWER
    THANX ALOT
    Jun 2011
    YCAV parts manual
    Hey, please find attached YCAV parts manual, which I think you might quote a wrong model#. Y=york;C/E=Chiller;A=air cooled;the 4th character is for compressor type.
    Apr 2011
    Hmm its york but made in china (yaep)
    Quote Originally Posted by Michael Shen View Post
    thanx Micheal Shen but the model is correct its york but made in china (johnson controls ) thanx again
    Jun 2011
    As far as I know, York got 2 factory in China, one is in Wuxi for water cooled chiller and another on is in Guangzhou for air-cooled chiller. Why dont refer to the China office?
    good old Europe
    YAEP is an aircooled recip chiller with PC compressors fitted. It is build in Guangzhou, China for high ambient applications. What does "failed high ambient" mean? Did it trip on high discharge pressure? If yes, on the electronic setting or on the mechanical hp´s? What was the condenser air inlet temperature when the chiller triped, did you have short circuit air flow, checked for refrigerant overcharge? The chiller should not trip on 37°C ambient at all! Have you checked correct fan rotation, operation. What is the setting for the condenser pressure control, electronic hp cut out, high ambient temperature cut out? I suspect, that you failed programing all values when you replaced the main board. Is a 031-01095-002 board fitted?
    "Quality exists, when the price is long forgotten."
    Henry Royce
    Apr 2011
    Confused YAEP LOADING CHART
    YAEP
    CAN ANY ONE GIVE ME THE CORRECT VALUE AND HOW TO PROGRAMME IT IN THE CHILLER
    Loading Charts - 2 System Units
    ITS IN PAGE 64 IN THE MANUAL WICH IM ATTACHED IT
    I MEAN CAN YOU GIVE ME THE DISCRIPTION FOR THIS PAGE AND HOW TO APPLY IT IN THE CHILLER
    THANXXXX
    good old Europe
    Quote Originally Posted by MOTASIM View Post
    If the chiller is new, as you said, it should be still under warranty of JCI/York. Sorry to say that, but the only thing you have to do in this case is, to call Johnson service office in your area. If everything is ok, the unit should not trip! But why have you replaced the main board then? Have you done it on your own and warranty is now void? I suspect as already said, that you missed to program the values which are factory set. What happened to the old board? Do you still have it? If you do want us to help you, you should try to answer the questions that we raise.
    Henry Royce
