Results 1 to 13 of 26
    Louisville,ky
    I've got a silly question about humidity
    I run my furnace fan on all the time for air conditioning.Now when I check my humidity, with Digital sling psychrometer,I get a reading 49% the temp. is at 76 indoor and outdoor temp is 86.Now my question is,when I check humidity when the A/C calls for cooling,than the furnance fan comes on in the auto position same temp.indoor and outdoor run it awhile,my humidity drops to 39%, just by having the fan come on with the A/C unit.So my point is,it still better to let the fan run all the time.THX
    4H: Hot, Humid Houston H.O.
    Most of the time your fan will consume enough KWH it will not be a good idea in terms of electric bills. There is an argument about humidity but from your report there is little to complain about. Probably you will see higher humidity if you let the fan run constantly without the AC.
    Hope this helps -- Pstu
    Jan 2010
    Quote Originally Posted by etap View Post
    The only time your dehumidifing is when your a/c is running.
    Nov 2008
    Bristol Va.
    when the fan is blowing room air across a wet evap. coil with water in the drain pan you will um how do I say pick up humidity and put it back into the house.
    this is why I never recommend running the fan in the summer.
    dogboy
    SW FL
    Thumbs down Stop it now
    N O ! !!
    Designer Dan
    It's Not Rocket Science, But It is SCIENCE with "Some Art".
    Nov 2000
    Eastern PA
    And the only time your IAQ features are working is when the blower is running. It depends on what kind of blower you have, what the settings are on the blower, what IAQ products are installed and what the stratification conditions of the house is as to whether or not it is a good idea to run the blower all of the time.
    I want my filter to be functional 24/7, so my blower runs 24/7. For the first time, I now have a variable speed blower. So, even though I never saw high electric bills from my previous psc motors, it will be even less now.
    Government is a disease...
    ...masquerading as its own cure…
    Ecclesiastes 10:2 NIV
    Jun 2001
    Moore, Oklahoma
    If you want higher humidity in the house, set the furnace blower to a higher cooling speed.
    Nov 2000
    Eastern PA
    Quote Originally Posted by 54regcab View Post
    Why would anyone want higher humidity during the cooling season?
    Jun 2001
    Moore, Oklahoma
    Quote Originally Posted by RoBoTeq View Post
    I guess I didn't quite understand the OP's question. It seems like he wants the humidity around 49%?
    Louisville,ky
    No I don't want 49% I just not aware the differences
    I've always left my fan in on position,because I thought it makes the temp.more even,plus the filter will do a better job,with the fan running,compare not moving any air,only on demand.
    I couldn't belive the differences,to remove humidity you would want to leave the fan in auto position,but if you want cool two storys,you would want to leave the fan on,right. THX
    Nov 2000
    Eastern PA
    Depends on what is most important to the circumstances. Or, as one guru of wisdom would say; "You can't always get what you want, but if you try sometime, you just might find, you get what you need."
    Nov 2008
    Bristol Va.
    I went to a call yesterday, compaint was too high of humidity level 71* and 75% rh. I asked him how long it had been too high and he said 2 weeks. We went to his t-stat and the fan was in the on position, I asked him how long the fan had been on he said about 2 weeks.
    I turned the fan to auto, let the a/c cycle once and almost 30 minutes after the a/c had shut off his humidty level was 70%. I don't know what stratification is but I do know more times than not fan on in summer raises the humidity level.
    dogboy
    SW FL
    Angry $$$ for Fans
    1 hp .... = 746 watts
    1 month = 720 hours
    1 hp-month = 537,120 watt-hrs = 537.12 kw-hrs
    @$0.10 /kw-hr = $53.70 / month = $644.54 / year
    ........... That's about 7, 8 or 9 months of electric bills for me.
    _______ 1/2 hp = $26.86 / month
    $$$ .. This is not cents
    or Is nonsense to me.
    Run any fans or pumps on an interval / timer.
    Designer Dan
