Results 14 to 23 of 23
    No straw, that's the pole for the umbrella at the table. Just looks like a giant straw!
    Feb 2007
    S.E. Missouri
    I sure didn't know the tall ones. How did you get them?
    Oh, I got a few tricks up my sleeve.
    Amazing! What else do you have on that relic?
    Feb 2007
    S.E. Missouri
    At least for 1967, available sizes for those type of units were 6, 8 (thought it was 7.5), and 10 ton units. Tandem units were available as 16 and 20 ton units. R-22 refrigerant. TXV metering device for indoor section. Bit heavy also, at over 700 lbs for the 6 ton unit.
    They are built! Know a model #?
    2 props sucking air in through the coil then it exits out the top?
    Feb 2007
    S.E. Missouri
    I'll scan the specs when I get home. Think I may have a color photo of one.
    Feb 2007
    S.E. Missouri
    Actually, I was wrong. Last column in specs is uncrated weight. The 6 ton is only 400 lbs. Kinda puny
    I like that right picture. Looks like GE did it the way Bryant did on the roof, the separate condenser and packaged gas heat.
    Quote Originally Posted by ACFIXR View Post
    I got a hundred bucks that says that all the "oil" filled run caps are still good in the GE.
    R-500 I think.No. I'm sure.
    I ran into an old 7.5 mf x 370 volt cap last week.
    About 8 inches long and as big as an oblonged pop can.
    Still working.
    GASP!
    THEY'RE GONE!
    The church replaced all for of those classics. Really splurged on the replacements, best name in commercial A/C!
