Results 1 to 13 of 16
    Jul 2005
    Just wondering what causes drains to smell like sewage. Thought it was the water but after putting some clorox in the traps, oder is gone. Trouble is, it comes back in a few weeks. This is a new house and I never had this problem at any other place I lived.
    Grottoes VA
    Is it your garbage disposal making the smell?
    You can fix that by grinding up a lemon.
    If it's in all the sinks, your traps are going dry. Most likely because the vent on your roof is plugged up.
    Note: I'm not a plumber, my butt is not big enough.
    Jul 2005
    No garbage disposal. Its just in bathroom sinks. only smells when water is running. Also on windy days, you can smell the vent gases outside. Is that normal? This is my first house with a 4" "mandatory" vent.
    Apr 2003
    Traps are not operating properly.
    Possible cause;
    The water is get sucked out. You may very well have a plugged vent that is allowing the water to literally get sucked out of the trap.
    Jul 2003
    Possible cause;
    Exactly the problem. You will need to have the plumbing vents cleaned out. It could be something as simple as a birds nest or venting in the attic could have been crushed.
    Jul 2005
    Thumbs up
    Thanks!!!
    Nov 2000
    Coastal Georgia
    Are you on a shallow water well near the coast?
    Sep 2001
    East Stroudsburg, PA
    There is sewage in there, resulting in the sewage smell. If there were fresh daisies, you'd experience fresh daiy smell.
    Sep 2001
    BTW, you are welcome.
    Howell, Michigan
    I had a friend who had that problem on windy days also. The vent pipe was situated in such a manner that when the wind blew it would create a suction on the vent pipe and suck the traps dry. He extended the vent pipe about 1' and problem cured.
    Nov 2001
    Moose Jaw, Saskatchewan, Canada Occupation:Interprovincial Plumber, Commercial Gasfitter Interests:
    The overflow on the basin is full of bacteria that is farting. Pour some thick toilet bowl cleaner in the overflow and the drain and let it sit. Then flush with hot water.
    I love my job, but paydays Thursday
    He extended the vent pipe about 1' and problem cured.-------------------------------------------------------
    Not quite as windy up there 1 more foot
    The change in altitude works every time
    Jul 2005
    Wasnt thanking you Dave, you dont seem to be smart enough to be of any help. Guys like you, who dont know how to do anything usually say stupid things. BTW "It is better to sit quietly and be thought a fool, than to speak and remove all doubt!!!"
