Results 1 to 10 of 10
Thread: Water source heat pump
06-11-2011, 11:06 PM #1
- Mar 2003
- Brooklyn, Ohio
- 102
I have a McQuay heat pump M/N CCH120AETS. The compressor seems to intermitently shut down and not restart until the power is reset. When i went out I found the following>>>suction 70# discharge pressure250#.suction line temp at comp 75deg. hot gas discharge temp180degr. cond water temp in was 86 and 100 out. not sure what design water temp rise should be.
it was running and stayed running the whole time I was there.
06-12-2011, 11:45 AM #2
I'm not familiar with that model number, but we service some water-cooled McQuay AHUs. Those units have condenser delta T of 10F at full load, so I would be looking for an explanation of why your equipment has a 14F delta T. May be OK, I'm just saying.
I'd also be looking at refrigerant charge and TXV performance, superheat seems high. If high SH were due to high load it seems like the suction pressure would be higher.
Have you tried to get the documentation online?
06-12-2011, 04:22 PM #3
- Apr 2010
- southern california
- 535
How large of an area is this unit serving. What is the flowrate through the condenser.
06-12-2011, 10:43 PM #4
- Mar 2003
- Brooklyn, Ohio
- 102
I found out comdenser water temp rise should be 10 to 14..so i think with high subcooling and high superheat it may be a txv or metering device as it looks like a fixed orfice.
06-12-2011, 11:00 PM #5
- Jan 2010
- 4,410
Go to McQuay's web site. You will find all kinds of info.
06-13-2011, 05:31 PM #6
- May 2006
- toronto
- 46
depending on your room temp i would lower the head pressure, if your room temp is 72 to 75 i would like it runing at 210 head
06-13-2011, 09:04 PM #7
- Mar 2003
- Brooklyn, Ohio
- 102
going back tues. going to check the water flow thru condenser then perhaps add a little refrigerant. the evap almost seems to be starving a bit.
06-14-2011, 07:46 PM #8
Guest
- Apr 2005
- where the beer flows like wine
- 2,871
14F temp rise is normal in cooling mode, place the unit in heating mode and see what it does. I hope the reversing valve isnt leaking (internally) these things are a pain to replace.
06-14-2011, 08:51 PM #9
- Mar 2003
- Brooklyn, Ohio
- 102
I added 1# R22 which brought the superheat closer to 12. My discharge pressure fell inline with the entering cond water temp. i am having the maintenance clean the evap coil as it does have some grease on it. I ended up with a 20 degree temp drop across the evap.
06-16-2011, 11:32 PM #10
- Mar 2011
- Southern California
- 17
Sounds like it was undercharged to me. I'd do a leak test and if you can't find one, isolate the water and test for a leak in the condenser loop. If you get a positive hit in the condenser, you can submit to replace the unit.
