Results 1 to 13 of 14
    Jun 2011
    Best insulation inside air handler?
    I'm wondering if anybody has any experience replacing the insulation inside an air handler. I have a situation where a condensate pan cracked and thoroughly saturated the fiberglass insulation inside a Carrier unit. I'm replacing the pan and want to replace the insulation, which is black and moldy now, but I wonder if there's any better alternative to the foil-lined fiberglass that Carrier provides. Does anybody have any experience or recommendations for a closed-cell product or something that might do a better job if it ever gets wet again?
    Thanks.
    Jul 2009
    Columbia, MD
    i have never done it before but i would use 1/2"-1" foam board and either glue it or use drives with screws to hold it in place.
    Dec 2010
    Palm Beach,Fl.
    I've used sheets of 1" Rubatex material with some success. Just gotta dry the unit really well and slather on some rubatex paint. Its a alot easier to work with than fiberglass IMO
    Quote Originally Posted by k-fridge View Post
    The laws of physics know no brand names.
    Sep 2011
    I need to do the same but I don't know if i can simply cut a sheet of styrofoam to the appropriate size and glue it on the bottom or if needs to be a different material. I'm considering styrofoam since it won't loose it's thermal properties if it gets wet.
    Jun 2010
    Philadelphia PA
    It doesn't matter what insulation you use
    because the mold didn't grow on the insulation. It grew because there was LIQUID WATER and Organic material (DIRT) So the mold would have grow on anything or more clearly, on any surface
    Apr 2010
    southern california
    Quote Originally Posted by henryp View Post
    I would be hesistant to use styrofoam. The flame and smoke spread needs to comply with UL in this application.
    south louisiana
    I'm with acwizard about using foams.
    there is a reason foam isn't approved for hvac.
    I don't use foam products in returns or anything
    hvac related. ductboard, duct wrap mastics.
    I think you need to address why there is so much condensation
    inside the unit. let me guess...ahu is located in attic?
    until you address why there is so much condensation
    you will be changing insulation often.
    best of luck
    Jan 2011
    Quote Originally Posted by energy_rater_La View Post
    best of luck
    he said his pan is cracked
    Southeastern Pa
    Have you asked Carrier if they use the original style of insulation in a retrofit situation, or if they have something else that is approved for the purpose?
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
    south louisiana
    my mistake about the pan location.
    there is a pan fix..asphalt I think.
    but pan has to be clean and dry
    and not rusted thru.
    best of luck.
    Virginia
    what about just leaving the insulation out of the inside and wrap the air handler with duct wrap, just a thought
    Jun 2010
    Philadelphia PA
    I like it
    Quote Originally Posted by catmanacman View Post
    How about a zipper for access
    Boise, ID
    http://www.armacell.us/WWW/armacell/...25775E003369BA
    Just about all insulation companies make fiber free duct liner if that's what you want, including Knauf, Rubatex and Owens Corning.
    Politicians need to be changed like diapers, and for the same reason.
    Mark Twain
