Results 1 to 13 of 27
Thread: New Install
    Ontario Canada
    New Install
    My latest install......
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	190282   Click image for larger version.
ID:	190292   Click image for larger version.
    Dec 2010
    Palm Beach,Fl.
    I know nothing about installing a furnace but it looks super clean man.
    Quote Originally Posted by k-fridge View Post
    The laws of physics know no brand names.
    Ontario Canada
    Quote Originally Posted by SoFlaDave View Post
    Thanks! Same thing the inspector said. (lol)
    May 2009
    In the Hudson Valley of New York
    Looks good to me, better watch out for the critics
    JK, you should do OK, some of the stuff posted here looks like wall of shame.
    Ontario Canada
    Quote Originally Posted by EugeneTheJeep View Post
    I welcome all CONSTRUCTIVE criticism.
    3?
    1-what size is that furnace?
    2-can you get to the far side of the c-pump to get the screw out?
    3-whats the other pvc pipe there?
    NE OHIO
    Quote Originally Posted by dandyme View Post
    2 I could
    3 WH
    Looks nice to me. Always been a fan of the "right angle" air cleaners.
    Ontario Canada
    Its a Payne 2 stage 80,000 Btu.
    Yes you can get the screw out on the c-pump, (thought about that myself after moving the DHW in place, screw can be reached with small 5/16 tech)
    Other Pvc Pipe is the DHW
    The right angle filter case is a real nice unit, saves a lot of time and looks clean. You can match the size of the drop with an adjustment on top...
    Gives the customers a larger surface area filter......
    Jan 2005
    Red Deer,Alberta
    Looks great ,not to knock but wondering what will happen in winter when vent exhaust leaves an icesicle by the window?The horizontal portion of exhaust is backgraded fr.outside to the furnace i'm sure but in real world my locale still translates to an outside sicle.
    Also,is that ss gear clamp w/screen on the intake?If it is these are the first place the intake will frost over in winter.With intakes I,ve had issues even w/2"dia.in ie.fall hoar frost gradually coning a restriction so instead put a tee on intake in lieu of the 90.The two openings on the tee alleviate this{also if there's powdery snow and swirling wind it lessens}
    Clearance fr.hwh vent to comb.air intake? Just wondering.
    Jan 2005
    Red Deer,Alberta
    Can't really see in pics but is that system636 pvc?At my location inspectors like to see evidence of primer{you know ,the purple crap that can end up all over}reason is becaus there was an allinone product that resulted in failed/leaking joints.I would use the clear primer product to clean off any stray purple crap for better look.
    Apr 2010
    Minnesota
    I don't do any install either, but it looks great. Only thing that jumps out at me is the furnace intake might frost up a little with the water heater vent being even with it.
    Ontario Canada
    dfelt;
    That SS gear clamp is not a gear clamp. It is a support bracket. It must be installed on all Payne installations according to the manufactures literature.
    When I went to get it at Carrier they said Not too many people put them in. But, the installation would not be CGA approved without that clamp.
    I did use the primer, it does not show up too well in the pictures. Embridge inspected and passed the installation.
    In Ontario, we Rarely get the snow levels and cold that you get. I am not anticipating any issues with the venting.
    The pictures don't do it justice, but the min clearance is 12" the distance between the exhaust of the furnace and intake of the hwt 14-16" I can not remember but I did note it when I installed it that it was more than min required.
