Results 1 to 13 of 15
    Yellow Jacket Vacuum Guage 69086 Problems
    I wish I had never heard of a micron... My first guage was a Jb it lasted 4 yrs and I think it died because it got wet-I then spent a little more and got the YJ 69086, it lasted 9months and then it would not read consistently. It got shipped back to YJ so they could fix it...a year later and it is doing weird stuff agian. Hooked up to my vac pump it read 20 microns in like 30 seconds, then I tested agian now it will not measure below 500, cleaned sensor with alcohol, before 1st test and after second test and now it will not go below 500. Any thoughts guys I am pretty pissed I use this thing to ensure I am doing quality work and it can not be trusted...
    Still learning opinions welcome.
    I've had to buy a new sensor once....because of the same issues you've described. Its a pretty simple change...costs around $45
    "The things you own end up owning you. "
    Tyler Durden
    Jul 2009
    Columbia, MD
    my problem was the plug the goes into the sensor. if i wiggled that plug my readings would change. i finally got rid of the POS and bought a bluvac. so far so good. only owned it a month. will update as time goes
    Jul 2009
    Columbia, MD
    and badboy....where u getting your sensors? i called carrier to get one and the price cost just about as much as a new one. so i ended up buying a new one
    Jan 2010
    Nebraska
    My first one just up and died, no display, nothing after a few weeks of use. Sent it in and after several months (distributor loosing it, not YJ's fault) I got it back and it's worked for one season. Now it's doing the same thing you describe. Cleaning doesn't seem to do anything for it. I have one more sensor left that came with my YJ digital manifolds, but after it breaks I'm going with another company. Too many problems after mild use in my opinion.
    Washington, DC
    I've had problems with it too. I got a new sensor for it and it's still all over the map. I had to buy a supco just to get a job done, even that one seemed iffy, I'm going to order the bluvac.
    Quote Originally Posted by gravity View Post
    I've bought a few things throught his co. and haven't had a problem.
    http://compare.ebay.com/like/1404929...=sbar&_lwgsi=y
    Tyler Durden
    i've changed the sensor in mine once in the three years i've had mine.
    least the Y/J allows you to change the sensor and not have to buy a whole new rig, that was the selling point for me...
    Aug 2009
    Regina,SK
    As soon as you get oil on that sensor it's screwed. Throws you for a real loop as it pulls down but not like it should....plus it rises quickly after valve off making you think you still have moisture or a leak. Learned my lesson and haven't changed one since.
    Feb 2012
    I know this is an old thread, but I've had no luck with the ones I've used and was looking around to see if other's had similar issues. Our company provides us with these micron gauges so I'm thankful for that, but the wires going to the gauge from the sensor is very wacky. If the wires moves at all, it throws the reading off. I'm using my manifold, I pull a vacuum and then hook up my micron gauge. I've had this issue on the other replacement guages they've supplied me as well even after cleaning them. I've heard of other techs having similar issues, but I'm guessing this is user error? I'd really like to go the trutechtools route as far as vacuum setups go (tee, gauge, hoses, etc.) but for now I have to stick with what I have.
    This is an old thread lol
    I still have this micron gauge and it still works flawlessly. Not sure about your wires. Possibly years of abuse. Usually the case with tools that are given instead of earned
    I have upgraded to the Fieldpiece micron meter recently, and since that purchase, I've obviously been using it.
    The connector going into the back of the sensor doesn't snap in very well and connect tightly. It's unfortunate because I like it overall but this is a flaw with the design of this particular micron gauge.
    Charleston, SC
    Jigjoe,
    I finally have a vacuum setup that works for me and is quick. I took the manifold set out of the process. Vac pump, 2 large vac hoses directly on the pump, 3 Appions VCRs and a Bluvac with rate of leak. 2 Appions back to back on the suction with Bluevac, 1 Appion on liquid. This is so I can close both Appions at the unit and test my pump, vac hoses and Bluevac. If it will pull well below 500, I don't care if the seals on the hoses or the hoses leak a small amount. (I use to change the seals anytime I suspected a leak and annually replace the hoses because they were part of the final tested vacuum.) When I want to test the actual vacuum in the unit, I close the liquid Appion and the Appion closest to the pump in the suction. Now the only leaks I'm concerned with are the double O-rings of the Appions that are rated to 20 microns and the connector to the Bluevac off the Appion. No manifold or hoses are part of the final test.
