Page 3 of 7 FirstFirst 1234567 LastLast
Results 27 to 39 of 86
  1. #27
    Nov 2000
    Coastal Georgia
    Originally posted by NormChris
    Originally posted by outside rep
    The newsletter is fantastic
    I would be happy to right something about sales or PM quoting maybe help some of the guys here that just give a one page qoute.
    You are going to "right" something or are you going to "write" something? Write would be the right word! Right?
    Bahaha Salespeople..saving the world.
  2. #28
    South Dakota
    Originally posted by RoBoTeq
    There was no way you could have passed that up, eh Norm ?
    The proper rule of Internet English grammar puts the question mark at the end of the sentence but before the smile.
  3. #29
    Aug 2005
    Originally posted by gruvn
    I have seen them , but I have not been asked to write for one of them yet. They are probably waiting for a special edition or something So I will bide my time.
    Yeah, you can school us on modulating cap tubes
    Cap tubes modulate ?
    I'll have to think about that one.
    I have thought about it and I have realized that yes, it is true that capillary tubes do modulate and meter the flow of refrigerant into the evaporator as the load demand changes. Nice observation Swampy
  4. #30
    South Dakota
    Yes it is true. When the heat load is highest you have the least liquid. When the heat load is the lowest you have more liquid refrigerant than you need.
    With an AEV that condition is even worse yet. The Automatic Expansion Valve actually throttles closed upon an increase in heat load. It starves the evaporator still more than a cap tube during high load conditions.
  5. #31
    Aug 2005
    No I believe that it works much the same way as a TXV rather than an AEV, when the heat load is the highest you will get the most liquid, considering a properly working system.When the load is the lowest you will get less liquid.
  6. #32
    South Dakota
    When the load on the evaporator increases, the greater amount of heat causes the refrigerant in the evaporator to boil away faster. The cap tube cannot open to allow more refrigerant to enter the evaporator. The greater the evaporator load, the more the evaporator is starved for refrigerant.
    As the evaporator load increases, the suction pressure and temperature increase and the entire lowside superheat increases.
  7. #33
    Aug 2005
    It does not need to open or close to modulate.All it needs do is speed up or slow down the flow, opening or closing an orifice is not the only way to accomplish this.
  8. #34
    Jul 2001
    Gold Coast of Connecticut
    I have been gettin the news letter and really enjoy it.
    As for the cap tube system, the capacity increases when the load increases in most aplications.
    Aire Serv of SW Connecticut- Gas heat, dual fuel and central a/c systems installed and serviced
  9. #35
    South Dakota
    Please continue. Inform us of what other factors are at work here. I know of another factor but that factor also works to "decrease" the flow under high load conditions.
    But, I would like to hear how you see the flow will increase with a cap tube during an increase in evaporator load conditions.
  10. #36
    South Dakota
    Please explain yourself. Just stating your position does not make it so.
  11. #37
    Aug 2005
    I will reply to your request in the morning, I am down with the flu right now and need to get some sleep, sorry to put you on hold but I don't have much choice at this point.
  12. #38
    South Dakota
    As the heat load increases the suction pressure increases and the superheat increases. The increase in suction pressure causes the pressure differential across the cap tube to decrease. This in turn causes LESS refrigerant to enter the evaporator.
    The evaporator starves for liquid refrigerant.
  13. #39
    Nov 2000
    Eastern PA
    No it doen't !
    I wanted my smiley to be part of the question...so there.
    ...seek, and ye shall find;..
    Ecclesiastes 10:2 NIV
