Results 1 to 13 of 22
    Nov 2010
    Southern Maine
    Einstein controller oil sep alarm
    worked on a small rack system today with a einstein controller,
    had a oil SEP alarm, checked oil separator gauge on filter was good, all compressors oil safetys were not tripped, and sight glasses were good, normal status and all circuit temps were fine and not alarming.
    just wondering what would may of cause this controller to alarm even though things appear to be normal.
    I'm just learning on this controller. Ive seen controllers before monitoring and send out alarms and things are okay.
    Jul 2005
    Southern California
    Is this a Temprite separator and the guage you said looked good is is the pressure differential indicator?
    Nov 2010
    Southern Maine
    It was a temprite separator and the pressure differential indication was between the green.
    wasn't even close to yellow or red.
    Quote Originally Posted by hvactech88 View Post
    Did you measure any pressures?
    Nov 2010
    Southern Maine
    no i didn't i should of checked, im on call for the weekend but if that comes in again i need to look into it more..
    Dec 2010
    new jersey
    I'm curious about this....can someone explain,I have not seen this type myself.
    I'm guessing from reading the post, the gauge will sense a diff. in press. and will indicate this on the dial by indicating yellow or red depending upon the diff. in press. indicating a clogged element.
    and then this is also connected to a digital input in the Einstein controller?
    I commonly see Henry separators and turbashed. but not this ,yet, anyway.
    A temprite separator has a paper element inside. Like any filter element, the filter loading is measured by pressure drop.
    A pressure drop of around 10# is threatening to burst.
    I've found 2 burst elements this year.
    They make a little diff pressure switch the does hook to a controller for alarming. That is why I asked the first question.
    Orange County CA
    I have seen them with a D.I. to an input...I think that's fancy and neato.
    I second the sep service.
    Jun 2011
    Barbados
    Thanks for the explination. I work on quite a few racks and I've not seen this type before, i think its a cool feature though.
    Quote Originally Posted by Gnarly View Post
    The pressure switch is an option. I've only seen them in catalogs...
    I just put a little chart up where I can record the pressure across the filter.
    Dec 2006
    In a Mess
    Ive set a notice and alarm for a pres diff across filter and it seemed to work Good!
    if in doubt replace!! haha
    Sig removed by mod. G-Rated site
